Analog inputs Aux 4 and Aux 5 Devo 8S
23 Dec 2015 17:58 #41102 by saidem
Many of us wonder if the modification concerning the addition of analog inputs (Aux 4, and Aux 5) is completed (see post Devo 8S Development Changes Adding Aux4 and AUX5) and we would like to know if the latest updates of deviation fit well or how to make such modification?
Many thanks
23 Dec 2015 19:24 #41104 by Deal57
Replied by Deal57 on topic Analog inputs Aux 4 and Aux 5 Devo 8S
I would expect this mod would work with both the 8 and the 6 because they mostly use the same processor connections. I've examined the connections on the 6 and it appears to me that there is nothing connected to the required pins.
This is mod that requires some soldering skills, but if it's not a lot of work to incorporate into the core functionality, it is probably less hassle than using the ppm-in pots.
24 Dec 2015 16:14 #41125 by saidem
Replied by saidem on topic Analog inputs Aux 4 and Aux 5 Devo 8S
Thank you for your answer.
For the welding work it should be fine, but for the rest, Deviation is it modified to receive these analog inputs?
By the way, I don't know using the ppm-in pots.
24 Dec 2015 17:54 #41126 by Deal57
Read the thread "Extra inputs for Devo TX". Opens up a lot of options!
25 Dec 2015 16:12 - 31 Dec 2015 16:20 #41133 by saidem
Merry Christmas and Happy New Year to everyone.
Thank you for your answer, but the subject that you have shown me especially regarding the Devo 7E, there was Randmental which began development in the topic "Adding Aux4 and AUX5" which seems much simpler, but I think n 'is not completed?
Last edit: 31 Dec 2015 16:20 by saidem. Reason: completed
Time to create page: 0.212 seconds
