Deviation Question
- sammy4703
03 Jan 2016 18:58 #41351
by sammy4703
Deviation Question was created by sammy4703
Please bear with this newbie if this question has already been asked!
Do test builds completely overwrite the nightly builds?
- magic_marty
03 Jan 2016 21:24 #41354
by magic_marty
Replied by magic_marty on topic Deviation Question
no, i was running the latest nightly with no problems and updated to the voice test build and everything still works the same as before i uploaded the voice test build...no problems for me trying the test builds..
04 Jan 2016 03:28 #41366
Replied by mwm on topic Deviation Question
The protocol files for the 7e are unlikely to work across different builds, since they depend on where things in the build wind up.
The various .ini files generally don't change, but that's not guaranteed. If they do change, it should be noted in whatever discussion there is in the test build. Mostly, .ini files carry forward: if you don't update them, you'll get default values for whatever they changed. However, you ought to update any that you haven't edited, just in case.
As a final warning, some of the test builds are for features that aren't supported in nightlies, and a model.ini file saved by one of those may not work if you try and go back to the nightly build.
- sammy4703
04 Jan 2016 10:24 #41374
by sammy4703
Replied by sammy4703 on topic Deviation Question
OK guys that's great - thanks!
Time to create page: 0.109 seconds
- Deviation Question
