Fail Safe in Plane Mode
- dr.wagen
05 Jan 2016 10:04 #41397
by dr.wagen
Fail Safe in Plane Mode was created by dr.wagen
I use Devo 7 TX many years and now bought Devo 10.
It is was surprise when I found that Fail Safe values can set up only in Heli model type.
This useful option for my quads and is any way to set this values in Plane (Standard GUI) type model?
- aMax
05 Jan 2016 10:25 - 05 Jan 2016 10:26 #41398
by aMax
Replied by aMax on topic Fail Safe in Plane Mode
Useless....
On quads this has to be handled by the flight controller....and the receiver.
Last edit: 05 Jan 2016 10:26 by aMax.
- dr.wagen
05 Jan 2016 10:33 - 05 Jan 2016 10:35 #41399
by dr.wagen
Replied by dr.wagen on topic Fail Safe in Plane Mode
Thanks, I know, but as I sad this is useful option, for example I can switch some parameters by settings fail safe values for knobs.
So it useful for me.
Last edit: 05 Jan 2016 10:35 by dr.wagen.
- aMax
05 Jan 2016 13:57 #41403
by aMax
On CF/BF this can be done, but only via CLI.
...and what is your flightsystem?dr.wagen wrote: Thanks, I know, but as I sad this is useful option, for example I can switch some parameters by settings fail safe values for knobs.
06 Jan 2016 02:32 #41422
Replied by mwm on topic Fail Safe in Plane Mode
Are you using deviation or devention? If you're using devention, then you're 1) in the wrong topic, and 2) might have better luck on a devention forum or a general RC forum.
If you're using deviation, you seem to be suffering from confusion about the two GUI's in deviation. There is a Standard GUI, which looks sorta-kinda like the devention interface. You can only use it with the Heli model type. So it doesn't make sense to talk about "Plane (Standard GUI) type model". You either have a Plane type model, or a Standard GUI, not both.
Failsafe is an Rx feature, not a Tx feature. It has to be - if the Tx has lost communication with the Rx, then it can't tell the Rx what to do! Some protocols have facilities to let the Tx send failsafe values to the Rx; others don't. Instead you do something on the Rx to use the current values from the Tx as the failsafe value (i.e. - a button on the Rx, set at bind time, etc). Those obviously don't care whether the Tx is in heli mode or not.
The Walkera protocols are the only ones that have Tx-sent failsafe values in Deviation. To set them, you have to use the Advanced GUI. Go into the mixer. select the channel name for an output channel, and the second setting controls the failsafe value for that channel. Hit Ent to toggle it between On and Off, and use the Left/Right keys to change the value when it's On.
The other one where the Tx has some bearing are the DSM protocols. Some Rx's record the values at bind time for a failsafe value, so Deviation lets bind count down to 0, then you set the switches/etc. to their failsafe positions, and then hit Ent to bind and set the failsafe values.
- dr.wagen
06 Jan 2016 07:52 - 06 Jan 2016 10:53 #41427
by dr.wagen
mwm
Thanks for explanation.
May I clarify?
1. Yes, I use Deviation
2. I need to set Chanel 8 in Fail Safe into high value (turn on beacon, for example)
Can you show what second setting you mentioned ?
PS And I know that DSM2/DSMX receiver store fail safe values during binding process. I was not sure about that it store all channels configuration.
Thanks that you confirm this.
May I clarify?
Last edit: 06 Jan 2016 10:53 by dr.wagen.
- RoGuE_StreaK
06 Jan 2016 20:11 - 06 Jan 2016 20:12 #41446
by RoGuE_StreaK
On the screen before that one, where you have "ch8" and "simple", instead of Entering through to "simple" go throught to "ch8" instead; it's also a button
Replied by RoGuE_StreaK on topic Fail Safe in Plane Mode
I knew I shouldn't have clicked the spoiler!dr.wagen wrote: Can you show what second setting you mentioned ?
Last edit: 06 Jan 2016 20:12 by RoGuE_StreaK.
- dr.wagen
06 Jan 2016 20:21 - 06 Jan 2016 20:28 #41447
by dr.wagen
Catch up! This is super. And I'm really blind.
Thanks a lot!
PS Sorry this is my habit - hide attach into spoiler.
PPS May I ask one thing as off-topic?
Tell me, please, is possible change screen fonts and where described requirements for them.
Thanks a lot!
Last edit: 06 Jan 2016 20:28 by dr.wagen.
06 Jan 2016 21:16 - 06 Jan 2016 21:17 #41451
I don't think you can change screen fonts, but I'm in a hospital waiting room , so can't check. Look in the media directory on the transmitter USB drive and set of there's a font file of some sort there.
Last edit: 06 Jan 2016 21:17 by mwm.
- dr.wagen
06 Jan 2016 22:07 - 10 Jan 2016 20:47 #41454
by dr.wagen
Thanks for help guys.
mwm - I see where fonts located, this isn't No.1 question, just not found any topic here related to this question.
PS Confirmed that RX616XN remember all 6 channels fail safe values at bind.
Last edit: 10 Jan 2016 20:47 by dr.wagen.
Time to create page: 0.405 seconds
- Fail Safe in Plane Mode
