Help with timer programming
- dr.wagen
12 Jan 2016 21:43 - 12 Jan 2016 21:43 #41693
by dr.wagen
Help with timer programming was created by dr.wagen
One of last things that I missed from original Devo firmware is counting timer when throttle >0.
I understand that this is possible in Deviation but really got lost.
I'm very appreciate for advise or link to topic.
Last edit: 12 Jan 2016 21:43 by dr.wagen.
- Jasenk
12 Jan 2016 23:52 - 13 Jan 2016 17:34 #41697
by Jasenk
-Jasen
Replied by Jasenk on topic Help with timer programming
For DEVO 10 at least, Under 1. Model Menu> 3. Timer is where you configure what you want for timer1, timer2, timer3 and timer4
You can choose Stopwatch, Stop-prop, Countdown, cntdn-prop. (see manual for details of timer function).
If you choose countdown you can say how many minutes and seconds you want.
Then you choose the switch you want to start stop / activate the timer. I use the throttle channel output i.e CH1, not the stick output because you can have Throttle Hold on with the stick up and not be counting. The Reset switch can be set to a switch or trim button for example but if you leave it to default "None" it will be "L" button on TX.
On the 1. Model Menu> 7. Main Page Config you will need to make sure the timer is added as a "Box#". Timer1, Timer2 etc... If it is not added go all the way to the bottom of config page past Menu 4 and select <Small-box>Add
Then assign the Box# <None> to the timer you want to display. (# will be 1,2,3,4,5 etc depending on how many small-boxes you already have.
I hope this helps.
I hope this helps.
-Jasen
Last edit: 13 Jan 2016 17:34 by Jasenk. Reason: Specified DEVO10
- Deal57
13 Jan 2016 03:37 #41703
by Deal57
Replied by Deal57 on topic Help with timer programming
On the Devo7e, you cannot use the GUI to add objects (like a timer box) to the main screen. You need to add them to the model.ini file manually. It's not difficult, since most model.ini files have a box or two already.
Edit your model.ini to add this line to the section called [gui-128x64]:You can also use this for a larger box, if there is room:The 2,40 is the X,Y position on the screen, 2 columns from the left (out of 128) and 40 rows down (of 64). Timer2 can be any of Timer1, Timer2, Timer3, or Timer4.
Happy Flying!
Small-box=2,40,Timer2Large-box=2,40,Timer2Happy Flying!
- dr.wagen
13 Jan 2016 16:04 #41716
by dr.wagen
Replied by dr.wagen on topic Help with timer programming
Thanks it is clear now!
Happy Flying!
Happy Flying!
Time to create page: 0.387 seconds
- Help with timer programming
