devo 7e ppm/trainer port acting funny
21 Jan 2016 13:08 #42035 by Eriksson
devo 7e ppm/trainer port acting funny was created by Eriksson
Hi i hope this is the right place to ask. Iam Using The devo 7e with deviation 4+ and i have connected a 433mhz system in The trainer port/ppm, iam Using all this to control a rc car.After i power on all is fine at first Using The ppm protocol, system gets ppm signal and it binds up as it should with The reciever on The car. Then The problem begins as soon The connection is solid The controller is acting out going in and out moving in The menus on its own as IF its getting input from Buttons and sticks.I used nightly build first but Then tried 4.0 and its less of a problem but still moving around.
So what could be The problem here? can ppm input make The controller acting like this?, IF so is it possible to disable ppm input and still Using a system like this?
Time to create page: 0.503 seconds
