not binding
31 Jan 2016 00:22 #42442 by hogan
not binding was created by hogan
Question/problem
Installed the A7105 and the nrf24l01+, flashed it and installed the nightly. Binding perfectly with the Syma x5, Hubsan X4, and the V911. My mSr, Hisky 80, and Walkera Super CP does not bind at all. All 3 copters LEDs are flashing but nothing. What am I doing wrong? I got all the ini files from here and I know they worked b/c they worked fine with my other flashed devo 7e.
here is my harware.ini files
[modules]
enable-cyrf6936 = B12
has_pa-cyrf6936 = 1
enable-a7105 = A13
has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
enable-nrf24l01 = A14
has_pa-nrf24l01 = 1
; enable-multimod = A13
31 Jan 2016 01:46 - 31 Jan 2016 01:52 #42444 by aMax
Replied by aMax on topic not binding
hogan wrote: Question/problem
[modules]
;enable-cyrf6936 = B12 <---
has_pa-cyrf6936 = 0 # if there is no range mod done, otherwise "1"
enable-a7105 = A13
has_pa-a7105 = 1
; has_pa-cc2500 = 1
has_pa-nrf24l01 = 1
That's why people don't read...
1.Comment the first line out.
2.Do not use a fixed ID for the first bind attempt.
Last edit: 31 Jan 2016 01:52 by aMax.
31 Jan 2016 02:32 #42446 by hogan
Replied by hogan on topic not binding
Nope. Didn't work.
31 Jan 2016 03:12 #42447 by aMax
Did you clear the flash on the SCP? (bind plug)
31 Jan 2016 05:37 - 31 Jan 2016 15:11 #42453 by hogan
Had the wrong protocol on the super, now working fine. MSr and hisky hfp not binding.
Just got HiSky HFP to bind, still struggling with the mSr
Last edit: 31 Jan 2016 15:11 by hogan.
31 Jan 2016 22:32 #42472 by mwm
Replied by mwm on topic not binding
Try both DSM2 and DSMX on the msr.
Also, make sure you set the number of channels in the model setup to the number used by the msr. There are known issues with some of the Spektrum AIO receivers like the msr uses if the Tx is set to 8 or more channels (which is why the default should be 7). There are also some oddities in the protocol when you go beyond 4 channels, though I don't think deviaiton has ever run into them.
01 Feb 2016 00:09 #42475 by hogan
Tried both and nothing. Just sits rapid flashing. tried it at 5 and 10 feet away and nothing.
Time to create page: 0.092 seconds
