Devo 7e Tx not recognised
- IflyallthingsRC
26 Feb 2016 08:04 #43662
by IflyallthingsRC
Devo 7e Tx not recognised was created by IflyallthingsRC
I can't seem to figure out what's wrong. I just can't seem to flash my Devo 7e. I'm using 2.0 defuse tool and have unzipped all files, I've located the driver folder, yet I'm still not successful. Since there aren't any instructions on official deviation instructions on how to install the driver, I've been following SebyDocky's tutorial on RCGroups (I've also looked at others as well). I'm following their instructions exactly and yet I can't install the driver. There is one differnece though andthat is that my Windows 8.1 PCrecognises the Devo 7e as a unknownUSB device, NOT a STM Device.
Would that have a effect? Am I doing something wrong? Any suggestions?
Here's a video with the problem:
drive.google.com/file/d/0BwPcQ_GJoRyKNkV...Mkk/view?usp=sharing
Thanks in advance,
IflyallthingsRC
Thanks in advance,
IflyallthingsRC
26 Feb 2016 12:54 #43669
Replied by mwm on topic Devo 7e Tx not recognised
In downloads -> dfu USB tool there's a dfu USB driver installer.you might try that. And the trick of unplugging all your USB devices except the 7e.
- aMax
26 Feb 2016 16:36 #43686
by aMax
Replied by aMax on topic Devo 7e Tx not recognised
You will need at least version 2.30 of this Walkera Dfuse tool.
Get it from here... walkera-fans.de/downloads/
- IflyallthingsRC
26 Feb 2016 21:32 #43714
by IflyallthingsRC
Replied by IflyallthingsRC on topic Devo 7e Tx not recognised
Can I use the one available from the deviation downloads section? (I don't understand German)
- IflyallthingsRC
26 Feb 2016 21:41 - 26 Feb 2016 21:50 #43716
by IflyallthingsRC
It still didn't work, the devo isn't recognized as a STM32 device. I've used the dfu USB driver installer and nothing changed. And I only have the Devo 7e plugged in, nothing else (except Power Supply to the PC)
I'm using the 2.31 version of the dfu USB upgrade tool.
mwm wrote: In downloads -> dfu USB tool there's a dfu USB driver installer.you might try that. And the trick of unplugging all your USB devices except the 7e.
Last edit: 26 Feb 2016 21:50 by IflyallthingsRC.
- RedSleds
26 Feb 2016 22:04 - 26 Feb 2016 22:19 #43718
by RedSleds
Also try using a USB 2.0 connection port (black port), instead of a USB 3.0 (blue port).
EDIT:
P.s.
You are holding down the EXT button when you power up your DEVO, right???
Replied by RedSleds on topic Devo 7e Tx not recognised
Just click on the folder that's says "Tools" (that's English, BTW) =O) , then select whichever version of DfuSe you want. I used v2.0 on my Windows 8.1 box, and it worked fine.IflyallthingsRC wrote: Can I use the one available from the deviation downloads section? (I don't understand German)
EDIT:
P.s.
Last edit: 26 Feb 2016 22:19 by RedSleds.
- aMax
26 Feb 2016 22:48 - 26 Feb 2016 22:53 #43721
by aMax
Use USB 2.0 ports as RedSleds advised and additional this tool >>>
www.nirsoft.net/utils/usb_devices_view.html
to verify which driver the cr...... Windows has installed for it..
download.cnet.com/USBDeview/3000-2094_4-10614190.html
Last edit: 26 Feb 2016 22:53 by aMax.
- IflyallthingsRC
27 Feb 2016 07:03 - 27 Feb 2016 07:07 #43754
by IflyallthingsRC
Didn't work unfortunately, any other suggestions/tips?
Here are a couple of images of what application said:
goo.gl/photos/ZvTx1FPeS1NAi3bC6
goo.gl/photos/D1tFMF3bzUCg49CBA
goo.gl/photos/A9ARULcBZnv1MtKP6
Maybe I should just buy a Spektrum dx5e?
Last edit: 27 Feb 2016 07:07 by IflyallthingsRC. Reason: Added images
- Thomas.Heiss
27 Feb 2016 11:28 - 27 Feb 2016 11:30 #43766
by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 7e Tx not recognised
What are you doing. Your cam record is 90 degree switched to vertical when you show your display screen?!? Funny..
Are you sure you have pressed the right button?
It is "EXT" on Devo 10, "ENT" is USB mode.
The DFuse tool will find your Devo transmitter in the "EXT" firmware flash mode.
Well, probably not with your yellow device manager signal
Maybe try a different computer?
BTW: I am using dfuse V1.7.0 on WinXP laptop with Devo10. Works as a charm
I would assume that the USB dfuse driver is just not compatible with your Win8.1? Maybe other drivers conflict?
Are you using the front or back USB port?
Spektrum Dx5e?
Come on...You probably mean Spektrum DX7 G2 (the new black one) or the on toy fair announced DX8G2 (antenna diversity)
Spektrum Dx5e?
Last edit: 27 Feb 2016 11:30 by Thomas.Heiss.
- aMax
27 Feb 2016 11:34 - 27 Feb 2016 11:39 #43767
by aMax
, but joke aside.
You seem to have a user restriction on your Windows OS. Try as admin or get somebody who knows how to do that.
As long as the driver "STTUB30,sys" does not appear, it will not work.
Just installed the tool ( version 2.31) by one click on a fresh Win7/64 and it was ok.
This can be an option...IflyallthingsRC wrote: Didn't work unfortunately, any other suggestions/tips?
cut----
Last edit: 27 Feb 2016 11:39 by aMax. Reason: ..typo
- aMax
27 Feb 2016 11:53 #43768
by aMax
RC(Devo), flight controller, esc, receiver flashing,STLinK V2,logic analyzing and more.
Not to forget, the FTDI gate did not work on XP...
Even nowadays a good way to go. Do all my technical stuff with such a device.Thomas.Heiss wrote:
......................... on WinXP laptop with Devo10. Works as a charm :-
- mario123
27 Feb 2016 18:02 #43778
by mario123
Replied by mario123 on topic Devo 7e Tx not recognised
I have used this one to upgrade my Devo 10 today.:
mega.nz/#!NN8ClSYC!HS0mCJTgmXKpi3fcYDAOGTeendy1Niq36E3duj-27qU
Link from this forum.
I'm using windows 10 64 bit with standard driver settings.
- IflyallthingsRC
27 Feb 2016 21:42 #43785
by IflyallthingsRC
OK, I'm going to run it as administrator using a older driver. Then if that doesn't work I'll give it a shot with my Windows 7 laptop, (why did I ever upgrade).
Thanks for your input everyone.
- IflyallthingsRC
28 Feb 2016 03:07 #43813
by IflyallthingsRC
Still didn't work, but this time (on my windows 7 laptop) a driver did install automatically upon pligging the tx in, the publisher was Windows though, so I would think if at that stage there was a option to manually select a driver it would work.
Any ideas left?
Any ideas left?
- Thomas.Heiss
28 Feb 2016 09:39 - 28 Feb 2016 09:40 #43824
by Thomas.Heiss
What happens on your Win7 when you do install the drivers from the dfuse folder and reboot?
Still yellow sign in device manager?
Last edit: 28 Feb 2016 09:40 by Thomas.Heiss.
- IflyallthingsRC
29 Feb 2016 21:02 #43910
by IflyallthingsRC
It doesn't let me install drivers from teg dfuse folder, it says that teh drivers are already uptodate.
- mario123
29 Feb 2016 21:11 #43913
by mario123
Plug your devo in. Then uninstall the driver by right clicking on the Devo 7e. And then install them again with the devo plugged in
- IflyallthingsRC
01 Mar 2016 07:31 - 01 Mar 2016 07:32 #43929
by IflyallthingsRC
I'll give it a shot tomorrow, very busy at the moment.
Last edit: 01 Mar 2016 07:32 by IflyallthingsRC.
Time to create page: 0.154 seconds
- Devo 7e Tx not recognised
