Question about Ch3-Popup while turning on.
10 Mar 2016 08:14 #44358 by HansT
I am running a DEVO7E with deviationtx. On my model I have PPM selected because I use TBS Crossfire as TX-Module. When I turn on the TX the Screen shows "Ch3 is 0%" "OK". Can I change this to Ch4? I can't find where to set this Parameter. I use Mode1.
Thank you,
Hermann
10 Mar 2016 09:14 #44362 by mwm
Documents in the online manual linked to the left hand menu as the safety section. You have to edit it on the USB drive, not the transmitter.
10 Mar 2016 09:34 #44365 by HansT
Replied by HansT on topic Question about Ch3-Popup while turning on.
Thank you, that helped and works fine now,
Hermann
Time to create page: 0.222 seconds
