Deviated Devo7E resets tx config setting each boot
20 Mar 2016 16:11 #44871 by Joshuad22
I have a Deviated 7E (latest nightly) w/ nRF module and everything works great with various models.
The problem is simply that the tx will not save it's config. settings. Each time I power on the tx I have to calibrate the sticks again. Thank you for any advice.
20 Mar 2016 16:30 #44874 by mwm
Sounds like the file system is corrupt. Connect it to a computer, copy all your model files off. Now format the drive, copy the file system from your distribution to it, and restore the model files. You'll need to recalibrate the tx, and possibly any other changes you made to it's configuration. And of course, if you've modified any other files - applied a theme, added icons, etc. - you'll have to put those back as well.
20 Mar 2016 20:55 #44887 by Joshuad22
Thanks for the hint.... Somehow I was missing the tx.ini file all together!
Thanks again, all of you guys are a huge help!
Time to create page: 0.096 seconds
