- Deviated Devo7E resets tx config setting each boot
- Joshuad22
20 Mar 2016 16:11 #44871
by Joshuad22
Deviated Devo7E resets tx config setting each boot was created by Joshuad22
I have a Deviated 7E (latest nightly) w/ nRF module and everything works great with various models.
The problem is simply that the tx will not save it's config. settings. Each time I power on the tx I have to calibrate the sticks again. Thank you for any advice.
20 Mar 2016 16:30 #44874
Replied by mwm on topic Deviated Devo7E resets tx config setting each boot
Sounds like the file system is corrupt. Connect it to a computer, copy all your model files off. Now format the drive, copy the file system from your distribution to it, and restore the model files. You'll need to recalibrate the tx, and possibly any other changes you made to it's configuration. And of course, if you've modified any other files - applied a theme, added icons, etc. - you'll have to put those back as well.
- Joshuad22
20 Mar 2016 20:55 #44887
by Joshuad22
Replied by Joshuad22 on topic Deviated Devo7E resets tx config setting each boot
Thanks for the hint.... Somehow I was missing the tx.ini file all together!
Thanks again, all of you guys are a huge help!
Time to create page: 1.009 seconds
