DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
26 Mar 2016 07:24 #45211 by Ng
I was upgrade DEVO 10 with firmware 4.0.1 , but not it bind with RX1002, help me.
28 Mar 2016 20:13 #45351 by josegabi
Had you try to bind a model with 4 channels ?
You can try to increase the number to 6 or more .... it runs to me...
29 Mar 2016 13:42 #45379 by Thomas.Heiss
Replied by Thomas.Heiss on topic DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
Sorry, I do not use Walkera DEVO stuff...but some ideas:
Auto-Bind? Fixed ID?
Have you tried to reset the ID with the bind plug on the RX1002?
Have you set 10CH?
How far are you away on binding? 2-3m++ from RX1002?
That usually fixes bind problems with Spektrum transmitters. Sometimes you can't stand just 30-50cm away with your TX from the RX.
Thomas
05 Apr 2016 21:32 #45867 by Artus
is this solved now .. i have such a combination - but my reciever is not aktiv - if you need help i will try You can write also PM
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Time to create page: 0.049 seconds
