- DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
- Ng
26 Mar 2016 07:24 #45211
by Ng
DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002 was created by Ng
I was upgrade DEVO 10 with firmware 4.0.1 , but not it bind with RX1002, help me.
- josegabi
28 Mar 2016 20:13 #45351
by josegabi
Replied by josegabi on topic DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
Had you try to bind a model with 4 channels ?
You can try to increase the number to 6 or more .... it runs to me...
- Thomas.Heiss
29 Mar 2016 13:42 #45379
by Thomas.Heiss
Replied by Thomas.Heiss on topic DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
Sorry, I do not use Walkera DEVO stuff...but some ideas:
Auto-Bind? Fixed ID?
Have you tried to reset the ID with the bind plug on the RX1002?
Have you set 10CH?
How far are you away on binding? 2-3m++ from RX1002?
That usually fixes bind problems with Spektrum transmitters. Sometimes you can't stand just 30-50cm away with your TX from the RX.
Thomas
Have you set 10CH?
Thomas
- Artus
05 Apr 2016 21:32 #45867
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic DEVO 10 Upgrade firmware 4.0.1 but no bind RX1002
is this solved now .. i have such a combination - but my reciever is not aktiv - if you need help i will try You can write also PM
Time to create page: 0.869 seconds
