Hotprops controller config
31 Mar 2016 17:26 #45505 by czindrick
Hotprops controller config was created by czindrick
Hello all!
So far I have a nightly build setup on my Devo 7e(does need to be updated). Used it with USB for FreeFrider and that worked great. After failed attempts at trying to get HotProps configured with it I decided to try the mono cable.
That took some configuring but FreeRider seems to be much better now that I have the controller configured correctly.
Now the only problem is on HotProps I always have a constant rise in throttle. And it does not seem to really accept inputs from the controller when calibrating. Now on the plus side it seems like throttle is held to about 20% at all times and when I move the throttle up it is speeding up.
I cannot for the life of me get any other inputs detected though, not sure if that is a bug in the system or if I am not doing something right....
Any help would be really appreciated as I want to try this out.
Thanks so much!!
Time to create page: 0.799 seconds
