Copy model to another slot
- mm-de
09 Apr 2016 12:19 #46168
by mm-de
Copy model to another slot was created by mm-de
From the manual and forum I understood it should be possible to copy a slot to another from the "Load" menu item.
I don't get it, pushing ENT loads the empty model slot, all other buttons do nothing.
Any help appreciated, I use a Devo 10.
- Thomas.Heiss
09 Apr 2016 13:36 #46171
by Thomas.Heiss
Replied by Thomas.Heiss on topic Copy model to another slot
In the File / Load you first need to load your model.
Once loaded go again into the Model setup / File dialog (Load...") but do not press ENT.
Press R / L buttons on the right side to switch "Load..." to "Copy to".
Hit ENT button.
Scroll down with DN button (on the left side) to the empty model slot you want to have the copy of your current loaded model.
Hit ENT button.
- TomPeer
09 Apr 2016 13:37 - 09 Apr 2016 13:39 #46172
by TomPeer
Replied by TomPeer on topic Copy model to another slot
when "Load" is highlighted, push the R or L button, then "Load" will change to: "Copy To...", "Template" and "Reset".
Edit: I was to late.
Tom
Tom
Last edit: 09 Apr 2016 13:39 by TomPeer.
- Arakon
09 Apr 2016 15:03 #46178
by Arakon
Replied by Arakon on topic Copy model to another slot
I also highly recommend looking at the model file manager that someone wrote and posted here some time back. Makes managing the files really easy on the PC.
- Sero
- RC-addicted
09 Apr 2016 16:17 #46185
by Sero
Replied by Sero on topic Copy model to another slot
I can highly second that!
I like to sort my aircrafts on my TXs by type, i. e. quad, heli, sail and so on, and have a little over 100 models, so each time, I create a new model, moving it to it's proper spot would be a huge job otherwise.
- mm-de
09 Apr 2016 22:02 #46228
by mm-de
Replied by mm-de on topic Copy model to another slot
Thank you all, I really didn't expect that <Load> to have another function below
10 Apr 2016 19:27 #46283
Replied by mwm on topic Copy model to another slot
The general rule is that if something has round ends, it's a buttton to push. If it has arrow-like ends, it can be changed. If it's got both, then it can be pushed. And sometimes, changing a value will change the shape. For example, protocols with protocol-specific buttons can be pushed to change those options, but those that don't can't be pushed.
Time to create page: 0.907 seconds
- Copy model to another slot
