can not download deviation-drvo10-v4.01
25 Apr 2016 18:23 #47178 by jkmorale@att.net
can not download deviation-drvo10-v4.01 was created by jkmorale@att.net
can not download deviation-devo10=v4.01 or when it does it will not unzip says file is corrup, also if I do ever get this downloaded do I need to update standard firmware first .Walkera doesent offer anymore it seems
25 Apr 2016 19:17 #47181 by PhracturedBlue
Replied by PhracturedBlue on topic can not download deviation-drvo10-v4.01
I verified that the download works ok for me. perhaps you should try a different browser?
This will replace the Walkera firmware altogether. If you would like to go back, there is a local copy of the Walkera official firmware here:
drive.google.com/folderview?id=0B3y72n5Y...xTDRGTnc&usp=sharing
25 Apr 2016 23:32 #47193 by RedSleds
Replied by RedSleds on topic can not download deviation-drvo10-v4.01
Works fine for me too.
Windows 8.1
using Internet Explorer 11, and also using Chrome. Both browsers work for me, and extract the .zip with no problem.
26 Apr 2016 14:31 - 26 Apr 2016 14:42 #47240 by Thomas.Heiss
Replied by Thomas.Heiss on topic can not download deviation-drvo10-v4.01
You should not download V4.01 release but instead of latest nightly-build: www.deviationtx.com/forum/3-feedback-que...-nightly-build#46790
Please guys & PhracturedBlue, at least delete the (final) release 4.0.1 directory and files from the download section as discussed in previous threads.
You are already planning for 5.0 release...so what.
Deviation-4.0.1: "WARNING: While this is the latest "official release", it is quite old and has known issues. (See the Bug Tracker)
If you want to take advantage of the latest bug fixes and new protocols, use the Nightly Builds."
Sorry, this is IMHO just not enough as noted in above threads short-term suggestions.
Would you please link the already summarized issue threads and more concrete warning about protocol (telemetry) and CYRF reset issues which had been fixed only in nightlies?
Pointing only to Mantis bugtracker tells nothing. Only sound like minor issues.
Thomas
Last edit: 26 Apr 2016 14:42 by Thomas.Heiss.
26 Apr 2016 20:30 #47259 by RedSleds
Thomas.Heiss wrote: Please guys & PhracturedBlue, at least delete the (final) release 4.0.1 directory and files from the download section as discussed in previous threads.
Thomas
Well, in my opinion it should not be deleted, but once v5.0 is officially released, it should then be moved to the "Older Releases" folder for legacy support reasons. Anyone that is new to DeviationTx should have done enough reading and research to know that v4.0.1 is ancient and the Nightly Builds are what they really need to be using. Besides, it is not that big of a deal to re-flash a Nightly Build when they figure it out at a later date.
I was a complete n00b when I got my DEVO 10, and even though I first flashed v4.0.1 to my un-modded Tx to make sure that it was indeed a working Tx when it arrived, by the time I started with the physical mods I knew that the Nightly Builds were what I needed to be using, including locally archiving the .zip files that I was using in case I had to revert back to one of them.
26 Apr 2016 21:58 #47270 by jkmorale@att.net
Replied by jkmorale@att.net on topic can not download deviation-drvo10-v4.01
hay thanks using chrome worked woohoo!!!
27 Apr 2016 09:51 #47296 by Thomas.Heiss
Probably this is beyond the thread title "can not download xxx firmware zip".
I am moving to 5.0 release thread: www.deviationtx.com/forum/6-general-disc...ments?start=20#47295
Time to create page: 0.105 seconds
