Devo 10 + DJI Phantom 3 Professional
- champstar2828
03 May 2016 23:44 #47703
by champstar2828
Devo 10 + DJI Phantom 3 Professional was created by champstar2828
Can you use a Devo 10 with deviation rx to fly a phantom 3 professional?
I am still a beginner, and can't seem to find a straight forward answer specifically with the devo10 and phantom 3 pro.
Also I am currently running latest nightly build. I have Naza flight assistant software installed.
Any input would be great.
- RoGuE_StreaK
04 May 2016 01:44 #47707
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 10 + DJI Phantom 3 Professional
I'm guessing not, but will leave it to the more informed.
From here :
Sounds like it may have been possible with the P2 as it essentially used Spektrum's FASST, but the P3 uses something else entirely? That said, I don't know if I'm correctly reading yours as a "P3", no idea what any of that means, I'm just googlin'
From here :
The P3 uses Lightbridge which is based on a proprietary protocol. It changes channels infrequently if at all. It is a bi-directional MIMO OFDM. The video downlink requires a lot of bandwidth in the 2.4GHz ISM band. Two P3s can interfere with each other's video signal. The RC control portion of that is done at a higher priority and is much less likely to be compromised.
Time to create page: 0.607 seconds
- Devo 10 + DJI Phantom 3 Professional
