Devo 10 + DJI Phantom 3 Professional
03 May 2016 23:44 #47703 by champstar2828
Devo 10 + DJI Phantom 3 Professional was created by champstar2828
Can you use a Devo 10 with deviation rx to fly a phantom 3 professional?
I am still a beginner, and can't seem to find a straight forward answer specifically with the devo10 and phantom 3 pro.
Also I am currently running latest nightly build. I have Naza flight assistant software installed.
Any input would be great.
04 May 2016 01:44 #47707 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Devo 10 + DJI Phantom 3 Professional
I'm guessing not, but will leave it to the more informed.
From here :
The P3 uses Lightbridge which is based on a proprietary protocol. It changes channels infrequently if at all. It is a bi-directional MIMO OFDM. The video downlink requires a lot of bandwidth in the 2.4GHz ISM band. Two P3s can interfere with each other's video signal. The RC control portion of that is done at a higher priority and is much less likely to be compromised.
Sounds like it may have been possible with the P2 as it essentially used Spektrum's FASST, but the P3 uses something else entirely? That said, I don't know if I'm correctly reading yours as a "P3", no idea what any of that means, I'm just googlin' ;)
Time to create page: 0.059 seconds
