Uploading to test builds
- silpstream
06 May 2016 17:10 #47886
by silpstream
Uploading to test builds was created by silpstream
Hi site admins,
I uploaded a build to the Test Build section of Downloads. However it showed up as a stand alone item as opposed to a folder(like) item that the rest of the builds are.
Did I do it correctly, or do I just not have enough permissions to create a folder?
07 May 2016 15:48 #47963
Replied by PhracturedBlue on topic Uploading to test builds
You should not have had permission to do that at all
There is a utility that 'Developers' can use to upload their files:
www.deviationtx.com/forum/7-development/...ly-to-the-test#30367
- silpstream
07 May 2016 16:37 - 07 May 2016 16:42 #47975
by silpstream
I'll go through the proper channels and PM you (PM sent).
I read through the link you provided as well as the perl file. I noticed that some updates were made for git. Did any of the instructions change from the post with regards to the deviationtx file to be created?
Thanks PB!
Replied by silpstream on topic Uploading to test builds
Whoops! How did that happen?PhracturedBlue wrote: You should not have had permission to do that at all
Thanks PB!
Last edit: 07 May 2016 16:42 by silpstream.
07 May 2016 17:13 #47978
If you can access the files, you already have developer access (which you should).
The instructions have not changed for git other than placing the necessary file in .git instead of .hg
- silpstream
07 May 2016 17:33 #47980
by silpstream
Thanks very much!
Time to create page: 0.693 seconds
- Uploading to test builds
