RX1002 Wont bind to Devo 10
06 May 2016 22:01 #47910 by champstar2828
RX1002 Wont bind to Devo 10 was created by champstar2828
I plug in the bind plug and the red light blinks. Then I turn off power unplug bind plug, turn power back on, but red led will not blink. It is supposed to be blinking faster but is not blinking at all. The Tx has fixed ID turned off. I followed instructions, but it does not seem to be working. Any ideas?
06 May 2016 22:04 #47911 by champstar2828
Replied by champstar2828 on topic RX1002 Wont bind to Devo 10
06 May 2016 22:55 - 06 May 2016 23:17 #47917 by Arnold
Replied by Arnold on topic RX1002 Wont bind to Devo 10
I believe the instruction you are referring to is missing a vital step or 2.
In that step 5, he says to "turn off" the fixed ID code. You actually have to delete the numbers that are in that field. But this is not the critical part.
Step 6. Re-insert the bind plug in the receiver.
Step 7. Power on the receiver and see a rapidly blinking red light.
Step 8. Power on the transmitter and (assuming you have chosen a Devo protocol for the active model) see the red light go solid.
Step 9. Remove the bind plug and power off the receiver.
Step 10. Power off the transmitter.
That's the initial binding that you must do.
You can continue on with his Step 5. to make a fixed ID.
Let me know if I've screwed up somewhere :-)
<Edit> About his missing something... his procedure is more about making a fixed ID and not about binding for the first time. From that standpoint his tutorial is OK, but his title is wrong.
Last edit: 06 May 2016 23:17 by Arnold. Reason: correction
07 May 2016 00:03 #47927 by champstar2828
Just tried and still same. The red light blinks slowly and does not connect when I turn on the tx. I have the latest nightly build firmware installed. I'm not sure if that is a factor.
07 May 2016 01:46 - 07 May 2016 01:49 #47937 by Arnold
It occurs to me now that you are not talking about the Deviation firmware, but the Devention firmware, right?
In the case of Devention firmware, yes, you do need to turn off the Fixed ID switch that is present. The Deviation firmware does not have a switch.
But, everything else should be the same. So, is that switch turned off in your transmitter? If not, tu;rn it off and try again, then report back.
Sorry to mislead you.
<Edit> Oops again! I see that you say you are using the latest nightly, so you must be using Deviation. So, no switch to contend with. But, why didn't it bind? stumped for the moment.
Last edit: 07 May 2016 01:49 by Arnold. Reason: correction
07 May 2016 02:35 #47943 by champstar2828
Currently running version devo10-v4.0.1-aa82a64
I believe this is deviation and not devention, but I could be wrong on that
07 May 2016 03:05 #47944 by champstar2828
I finally got it to bind. Thank you Arnold for your input. I had to overcome a couple of issues. 1st I had to connect the power to the batt port, also found out I had my wires upside down going into the rx.
Finally binded now. Can't wait to fly.
07 May 2016 03:21 #47946 by Arnold
Great job! Never quit - persistence always pays off.
07 May 2016 04:13 #47948 by champstar2828
Now my problem is getting baseflight to recognize aux inputs from the tx. Throttle roll pitch work, but aux doesn't seem to work. I calibrated the tx.
Also where can I find the endpoint settings?
07 May 2016 08:28 #47952 by aMax
Replied by aMax on topic RX1002 Wont bind to Devo 10
Set/assign these switches in the flight controller software.... Baseflight-Configurator > modes.
07 May 2016 22:38 #47995 by champstar2828
I can do that in baseflight, but baseflight will not recognize the aux input. After more research, I want to assign FDMODE1 to aux 1. How can this be done?
Thank you
08 May 2016 01:59 #48016 by champstar2828
How can I set end points? In clean flight my YAW is set to 1900 any little move will arm the motors. I'm still trying to set this thing up after 2 days 0 flights.
08 May 2016 02:55 #48017 by champstar2828
Found how to set end points. Have to go under mixer on tx and adjust settings. Now I have a problem with my rudder. I will not center
it is either low or high and arms the motors. I'm not sure what to do. I'm giving up for now.
08 May 2016 09:00 - 08 May 2016 19:24 #48025 by aMax
champstar2828 wrote: Found how to set end points. Have to go under mixer on tx and adjust settings. Now I have a problem with my rudder. I will not center
Subtrim does the magic.
My advice, switch to cleanflight since there are great documentation files about anything you need to know.
Lack of knowledge and a weak setup will cause you to crash more than necessary..
Last edit: 08 May 2016 19:24 by aMax. Reason: typo
08 May 2016 18:01 #48056 by champstar2828
Thank you everyone who commented. I finally have it flying.
My fixes.
1. Flash to cleanflight
2. Calibrate tx
3. check model.ini file and made sure all channels were set up right.
4. Change end-points under model menu, mixer
5. Set channel6 to fdmode0 to use aux switch to change flight modes
Done.
It took me a while, but I think I have the first part set. Now I am learning how to set the 3 position switches.
I get it to switch only between high and low. How can I use the full 3 range?
08 May 2016 19:32 #48066 by aMax
Wrong topic here....
This not part of the Deviation software, use the Cleanflight - Configurator (modes) to assign a valid range to each function.
Time to create page: 1.789 seconds
