Frsky D8 Telemtry
03 Jun 2016 08:12 #49854 by Alexandro
Replied by Alexandro on topic Frsky D8 Telemtry
Test Ver. 664,D8R,Hub,Alt,Fas-40
On Test set to 0 Datas (VoltA,Amp) are displayed, but not constant. After few Seconds the Fields going red and then return to normal.
VoltA and Amp showing the real Numbers but not constant on Display .
Alt does show always but it stops the refreshing on same Time as VoltA and Amp going red.
Data Log with Test set to 1
File Attachment:
File Name: datalog-2.txt
File Size:16 KB
greetings Alex
03 Jun 2016 18:32 #49893 by hexfet
Replied by hexfet on topic Frsky D8 Telemtry
Thanks. From the log it looks like the display probably behaved the same when TEST was 1. Is that correct?
Don't have any more likely guesses to make. Something needs to be sent in packet bytes 4 and/or 5 to keep telemetry flowing, but not sure what. With the current code it runs for a bit, stops, then repeats. Really need some captures from a stock Frsky tx module while hub telemetry is running to make progress.
Will make a PR to display negative temperature values correctly.
07 Jun 2016 02:46 #50073 by hexfet
Alex, would you please use the same test build to make a datalog capture with TEST=1 and without the sensor hub (using the vario to connect the fas-40)? I'd like to see if there's any change in the sequence or if the current code is fine.
09 Jun 2016 09:54 #50239 by Alexandro
here is the Log File
File Attachment:
File Name: datalog-2-3.txt
File Size:16 KB
greetings Alex
09 Jun 2016 23:27 #50291 by hexfet
Thanks Alex. Looks like even without the hub we'd get better results if we knew the proper values to send from the tx. Thinking maybe a test build with an Frsky sniffer, but haven't checked difficulty level yet...
10 Jun 2016 05:04 - 10 Jun 2016 05:05 #50310 by Alexandro
yes with out the Hub is can be used.
The Amp is a little slow but it works for most Applications , only the 0.5 Amp without Servos looks a bit high. Here i will test next Days with Taranis and booth FAS (40 / 100) and report.
It looks like there are not to much Users of the D8 Protocol ,so i think we should take the best out of the given Point at the Moment and do a deep Bug check on d8 and x8.
To get a good working Frsky Protocol.
greetings Alex
Last edit: 10 Jun 2016 05:05 by Alexandro.
12 Jun 2016 22:05 #50490 by hexfet
I don't plan on any changes unless I can get more information about the transmit values. Should be finished unless testing turns up something.
30 Dec 2016 23:40 #57379 by Rhodizzle
Replied by Rhodizzle on topic Frsky D8 Telemtry
Hey guys,
I'm reading through this thread and I think what I'm reading is that hub telemetry was added for the D8 protocol correct? Was that set of code merged back into the main nightlies or do I have to load a specific version of DeviationTX to get it going?
31 Dec 2016 01:30 #57382 by hexfet
That's correct. It's in the nightly builds. User manuals with updated information are in the test build section (and the deviation-manual repo).
Time to create page: 0.798 seconds
