Internal antenna questions
- Josh69
03 Jun 2016 09:23 #49863
by Josh69
Internal antenna questions was created by Josh69
Hi! I have some antenna that I'm not using those taken from a router I had laying around. The router was a dual-band 2.4GHz and 5GHz. How do I know which of the antennas that work to 2.4GHz?
drive.google.com/file/d/0B2u-o3FyPvNhMmp...lE/view?usp=drivesdk
- Cereal_Killer
03 Jun 2016 12:08 #49868
by Cereal_Killer
Replied by Cereal_Killer on topic Internal antenna questions
Well the T shaped ones say 2.4 on them...
- Josh69
03 Jun 2016 12:30 #49869
by Josh69
Replied by Josh69 on topic Internal antenna questions
Well I've seen it too. So it should be those two are to 2.4GHz. It just becomes poor range if it would still be wrong and the antenna is 5GHz? Nothing that will break if it is wrong?Cereal_Killer wrote: Well the T shaped ones say 2.4 on them...
- HappyHarry
03 Jun 2016 12:42 #49871
by HappyHarry
Replied by HappyHarry on topic Internal antenna questions
2.4 has a larger wavelength than 5.8, so even without the 2.4 markings you can tell the t shaped ones are 2.4ghz antennae
Time to create page: 0.095 seconds
- Internal antenna questions
