Trainer port PPM and input tension (Hitec opti 6)
03 Jun 2016 14:44 #49877 by TheSFReader
Hi, I'd like to use my Devo7E in a buddybox config with an oldee Hitec optic 6 (non sport) transmitter.
Did anyone do such a connection ?
I've found a few pages on the web on how to electrically connect them (one side with the 3.5 jack, the other with a 6 pins DIN), but wonder if there are any traps.
1st, I'm not sure what the max tension on the Hitec trainer out signal is, and if it could be problematic. Any idea on the max tension on the devo 7e trainer port ?
2nd, I understand there is "positive" and "negative" shift PPM. Is the devo ok with both ? Would swapping the wires be necessary/sufficient ?
Time to create page: 0.122 seconds
