stupid questions!
08 Jun 2016 16:08 - 08 Jun 2016 16:13 #50181 by tboneportly
stupid questions! was created by tboneportly
Hi
I updated my devo 7E with deviation, and I seem to have all the protocols, but I can't bind it to a MJX X600. do I need a model.ini file for this specific model? or do I just set it up using the menus and click the re-init option?
the process I am using is:
turn on hex
turn on tx
model menu > model setup >
model type - multi
Tx power - default
PPM In - None
*MJXq
select Re-Init > press ENT nothing happens...
any clues much appreciated
thanks!
Last edit: 08 Jun 2016 16:13 by tboneportly.
08 Jun 2016 16:53 #50185 by HappyHarry
Replied by HappyHarry on topic stupid questions!
you will need to add and enable an nrf24l01 rf module to enable use of the mjx protocol
09 Jun 2016 08:34 - 09 Jun 2016 09:50 #50237 by tboneportly
Replied by tboneportly on topic stupid questions!
thanks for the info - probably not what I want to be doing right at the moment.... next question!
what module would I need in the 7E to connect to APM 2.8 module in the hex I am building? If it needs the NRF24L01 I might do the mod, if it will use whatever is in there that's great, or I may buy a tx with the right module in it already.....
or, thinking about it, does that fact that I'm using a devo RX701 receiver in the hex mean that it will all be OK?
cheers!
Last edit: 09 Jun 2016 09:50 by tboneportly.
09 Jun 2016 10:42 #50241 by tboneportly
could I take the module out of the MJX 600 tx?
09 Jun 2016 11:51 #50243 by Arakon
Replied by Arakon on topic stupid questions!
You need no modification or module at all if you're using a devo receiver.
The modification is only needed if you want to use a receiver that is NOT Devo or Spektrum.
09 Jun 2016 12:13 #50244 by Nitro_123
Replied by Nitro_123 on topic stupid questions!
Also if you're using the 7e try and do the range mod before you do any serious flying :)
Time to create page: 0.307 seconds
