stupid questions!
- tboneportly
08 Jun 2016 16:08 - 08 Jun 2016 16:13 #50181
by tboneportly
stupid questions! was created by tboneportly
Hi
I updated my devo 7E with deviation, and I seem to have all the protocols, but I can't bind it to a MJX X600. do I need a model.ini file for this specific model? or do I just set it up using the menus and click the re-init option?
the process I am using is:
turn on hex
turn on tx
model menu > model setup >
model type - multi
Tx power - default
PPM In - None
*MJXq
select Re-Init > press ENT nothing happens...
any clues much appreciated
thanks!
turn on hex
turn on tx
model type - multi
Tx power - default
PPM In - None
*MJXq
thanks!
Last edit: 08 Jun 2016 16:13 by tboneportly.
- HappyHarry
08 Jun 2016 16:53 #50185
by HappyHarry
Replied by HappyHarry on topic stupid questions!
you will need to add and enable an nrf24l01 rf module to enable use of the mjx protocol
- tboneportly
09 Jun 2016 08:34 - 09 Jun 2016 09:50 #50237
by tboneportly
Replied by tboneportly on topic stupid questions!
thanks for the info - probably not what I want to be doing right at the moment.... next question!
what module would I need in the 7E to connect to APM 2.8 module in the hex I am building? If it needs the NRF24L01 I might do the mod, if it will use whatever is in there that's great, or I may buy a tx with the right module in it already.....
or, thinking about it, does that fact that I'm using a devo RX701 receiver in the hex mean that it will all be OK?
cheers!
cheers!
Last edit: 09 Jun 2016 09:50 by tboneportly.
- tboneportly
09 Jun 2016 10:42 #50241
by tboneportly
could I take the module out of the MJX 600 tx?
- Arakon
09 Jun 2016 11:51 #50243
by Arakon
Replied by Arakon on topic stupid questions!
You need no modification or module at all if you're using a devo receiver.
The modification is only needed if you want to use a receiver that is NOT Devo or Spektrum.
- Nitro_123
09 Jun 2016 12:13 #50244
by Nitro_123
Replied by Nitro_123 on topic stupid questions!
Also if you're using the 7e try and do the range mod before you do any serious flying
Time to create page: 0.267 seconds
- stupid questions!
