Help- white screen after upgrade
- Topher
09 Jun 2016 16:52 #50258
by Topher
Help- white screen after upgrade was created by Topher
I just upgraded my devo 10 to 5.0.0 and when I turn it on, I just get a white screen. It seems to be transmitting, but not all channels seem to be working. Did the initial upgrade using the deviation tool (java)in OSX and when it did this, I switched to windows and the walkera tool. I reinstalled it using that, but no better. I reinstalled the version of 4.0.1 from before, but still a white screen. what can I do?
-Topher
-Topher
- magic_marty
09 Jun 2016 17:10 #50260
by magic_marty
Replied by magic_marty on topic Help- white screen after upgrade
Try format then reinstall ..be sure you have a copy of your model files and any other file you want save on the tx before you format...
- Topher
09 Jun 2016 17:55 #50263
by Topher
Replied by Topher on topic Help- white screen after upgrade
Tried that, still nothing. I can still boot into USB mode and see the files. How could I adjust brightness and contrast with software?
-Topher
-Topher
- HappyHarry
09 Jun 2016 18:08 #50264
by HappyHarry
Replied by HappyHarry on topic Help- white screen after upgrade
do you have any extra modules installed?
- Cereal_Killer
09 Jun 2016 18:53 #50265
by Cereal_Killer
Replied by Cereal_Killer on topic Help- white screen after upgrade
You can edit the tx.ini file. This is where the tx remembers settings like brightness/contrast, model to boot up in and calibration points for all the inputs.Topher wrote: I can still boot into USB mode and see the files. How could I adjust brightness and contrast with software?
- Topher
09 Jun 2016 20:28 #50267
by Topher
I looked at the tx.ini file and don't see anything related to brightness or contrast. Do I need to add some command? Also, I was checking out a flying wing and it seemed like some of my mixes were functioning but not others. Any thoughts?
-Topher
-Topher
- Topher
09 Jun 2016 22:59 #50285
by Topher
Problem solved, I think. There was a blob of solder stuck to one of the pins on the plug for the LCD. Popped that off and it works, so far. Thanks to those who gave my problem some thought.
-Topher
-Topher
Time to create page: 0.593 seconds
- Help- white screen after upgrade
