Help- white screen after upgrade
09 Jun 2016 16:52 #50258 by Topher
Help- white screen after upgrade was created by Topher
I just upgraded my devo 10 to 5.0.0 and when I turn it on, I just get a white screen. It seems to be transmitting, but not all channels seem to be working. Did the initial upgrade using the deviation tool (java)in OSX and when it did this, I switched to windows and the walkera tool. I reinstalled it using that, but no better. I reinstalled the version of 4.0.1 from before, but still a white screen. what can I do?
-Topher
09 Jun 2016 17:10 #50260 by magic_marty
Replied by magic_marty on topic Help- white screen after upgrade
Try format then reinstall ..be sure you have a copy of your model files and any other file you want save on the tx before you format...
09 Jun 2016 17:55 #50263 by Topher
Replied by Topher on topic Help- white screen after upgrade
Tried that, still nothing. I can still boot into USB mode and see the files. How could I adjust brightness and contrast with software?
-Topher
09 Jun 2016 18:08 #50264 by HappyHarry
Replied by HappyHarry on topic Help- white screen after upgrade
do you have any extra modules installed?
09 Jun 2016 18:53 #50265 by Cereal_Killer
Replied by Cereal_Killer on topic Help- white screen after upgrade
Topher wrote: I can still boot into USB mode and see the files. How could I adjust brightness and contrast with software?
You can edit the tx.ini file. This is where the tx remembers settings like brightness/contrast, model to boot up in and calibration points for all the inputs.
09 Jun 2016 20:28 #50267 by Topher
I looked at the tx.ini file and don't see anything related to brightness or contrast. Do I need to add some command? Also, I was checking out a flying wing and it seemed like some of my mixes were functioning but not others. Any thoughts?
-Topher
09 Jun 2016 22:59 #50285 by Topher
Problem solved, I think. There was a blob of solder stuck to one of the pins on the plug for the LCD. Popped that off and it works, so far. Thanks to those who gave my problem some thought.
-Topher
Time to create page: 0.602 seconds
