devo7e with RFM23BP module
28 Jun 2016 06:07 #51135 by xfce
devo7e with RFM23BP module was created by xfce
I have upgraded my devo7e with deviationtx, and use the PPM out to oplink(with RFM22 module and max power is 100mW)
If the module's power set to high level,such as 100mW, when the antenna close to the LCD, menu will go to be mass, seems RF EMI cause the firmware's ScanButtons function get the button press. and when set to lower power level, it is OK. I also use my amateur radio do the test, got same results.
is it possible to improve the firmware's ScanButtons function to reduce the RF EMI
Time to create page: 0.223 seconds
