Devo 7e
- xMrAwesome24
12 Jul 2016 17:59 - 12 Jul 2016 18:22 #51579
by xMrAwesome24
Devo 7e was created by xMrAwesome24
Hi, So I just put the Deviation Firmware in my Devo 7e. And I am trying to bind to an SLT reciever, but when I try to bind, it says "Re-Init". What do I do to bind if that shows up? And what does it mean?
Last edit: 12 Jul 2016 18:22 by xMrAwesome24.
- victzh
12 Jul 2016 18:30 #51580
by victzh
Replied by victzh on topic Devo 7e
There is a manual at
www.deviationtx.com/user-manual/user-manual-7e-10
, the relevant chapter is
www.deviationtx.com/manuals/html-devo10/...odel.html#model-menu
- xMrAwesome24
- xMrAwesome24
- victzh
12 Jul 2016 19:17 #51584
by victzh
As far as I can recall, you turn on TX first, you turn on the receiver and press bind button on receiver. On TR624 it's called LINK. See the manual for the receiver -
manuals.hobbico.com/tac/tacl0624-manual-v2.pdf
Re-init on Deviation means that you don't need to do anything on TX to bind, just turn it on. It's basically what's written in the manual.
- xMrAwesome24
- victzh
13 Jul 2016 16:31 #51606
Replied by mwm on topic Devo 7e
The SLT protocol hasn't been well-tested. In particular, we've had reports (including mine) of timing issues with some SLT aircraft, but the stock Tx seems to have the same issues, so we're not sure if it's an issue with deviationTx or the aircraft.
Please let us know how this works out for you.
Time to create page: 0.227 seconds
