DEVO 7E and 10 5.0 manual
11 Aug 2016 16:29 #52679 by captjack01
DEVO 7E and 10 5.0 manual was created by captjack01
Howdy
I have been trying to download the new manual for 7E and 10 version 5.0 and keep getting a blank document. Download folder shows 1.9mb but nothing shows up in the document when I open it. 4861% shows up in the size box at the top but when I try to reduce it the blank white page gets smaller but no text ever shows up. I've tried both links and get the same results. The 4.0 version shows up fine.
Is there another way to download the 5.0 version?
John
11 Aug 2016 20:56 - 11 Aug 2016 20:57 #52683 by RoGuE_StreaK
Replied by RoGuE_StreaK on topic DEVO 7E and 10 5.0 manual
I can confirm that the PDF doc seems to be screwed; is this an auto-generated thing from bitbucket?
https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation10UsersManual.pdf
Last edit: 11 Aug 2016 20:57 by RoGuE_StreaK.
11 Aug 2016 21:11 #52684 by FDR
Replied by FDR on topic DEVO 7E and 10 5.0 manual
Adobe Acrobat Reader DC can't open it indeed, however Chrome can.
BTW the version is obsolete on the cover page...
11 Aug 2016 23:00 - 11 Aug 2016 23:06 #52686 by Arnold
Replied by Arnold on topic DEVO 7E and 10 5.0 manual
RoGuE_StreaK wrote: ... is this an auto-generated thing from bitbucket? ...
Yes, it is auto-generated, but not from bit bucket. Everything was moved to GitHub several months ago. I don't believe it is a function of GitHub, but I'm not clear about the mechanics of how it works. Something seems to be broken.
I recommend using the online version of the manual rather than downloading the PDF version. You can do that from the sidebar here on the left side of the page.
Last edit: 11 Aug 2016 23:06 by Arnold.
12 Aug 2016 00:52 #52688 by captjack01
Replied by captjack01 on topic DEVO 7E and 10 5.0 manual
Howdy
Thanks for all the replies. I went to WIKI and opened it there then saved each page to file. Now I can print it out and scribble my notes all over it as I go along. I got Phoenix 5.5 and both the 7E and the 10 working with it. Now to finish my trex450 Dominator and figure out an ini for it.
This site is great.
Thanks to all involved.
John
25 Aug 2016 15:41 #53094 by lkedmiston
Replied by lkedmiston on topic DEVO 7E and 10 5.0 manual
Thanks guys, it never occurred to me to open it with Opera! The next question, however, this says ver 4.1-dev. Is this manual older than the one on the home page?
25 Aug 2016 17:06 - 25 Aug 2016 17:07 #53097 by Arnold
lkedmiston wrote: ..., this says ver 4.1-dev. Is this manual older than the one on the home page?
I believe it's just the cover has the wrong date & version. The last part of the installation section talks about version 5.0.
Last edit: 25 Aug 2016 17:07 by Arnold.
Time to create page: 0.142 seconds
