DEVO 7E and 10 5.0 manual
- captjack01
11 Aug 2016 16:29 #52679
by captjack01
DEVO 7E and 10 5.0 manual was created by captjack01
Howdy
I have been trying to download the new manual for 7E and 10 version 5.0 and keep getting a blank document. Download folder shows 1.9mb but nothing shows up in the document when I open it. 4861% shows up in the size box at the top but when I try to reduce it the blank white page gets smaller but no text ever shows up. I've tried both links and get the same results. The 4.0 version shows up fine.
Is there another way to download the 5.0 version?
John
John
- RoGuE_StreaK
11 Aug 2016 20:56 - 11 Aug 2016 20:57 #52683
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic DEVO 7E and 10 5.0 manual
I can confirm that the PDF doc seems to be screwed; is this an auto-generated thing from bitbucket?
https://bitbucket.org/deviationtx/deviation-manual-rst/downloads/Deviation10UsersManual.pdf
Last edit: 11 Aug 2016 20:57 by RoGuE_StreaK.
11 Aug 2016 21:11 #52684
Replied by FDR on topic DEVO 7E and 10 5.0 manual
Adobe Acrobat Reader DC can't open it indeed, however Chrome can.
BTW the version is obsolete on the cover page...
- Arnold
11 Aug 2016 23:00 - 11 Aug 2016 23:06 #52686
by Arnold
I recommend using the online version of the manual rather than downloading the PDF version. You can do that from the sidebar here on the left side of the page.
Replied by Arnold on topic DEVO 7E and 10 5.0 manual
Yes, it is auto-generated, but not from bit bucket. Everything was moved to GitHub several months ago. I don't believe it is a function of GitHub, but I'm not clear about the mechanics of how it works. Something seems to be broken.RoGuE_StreaK wrote: ... is this an auto-generated thing from bitbucket? ...
Last edit: 11 Aug 2016 23:06 by Arnold.
- captjack01
12 Aug 2016 00:52 #52688
by captjack01
Replied by captjack01 on topic DEVO 7E and 10 5.0 manual
Howdy
Thanks for all the replies. I went to WIKI and opened it there then saved each page to file. Now I can print it out and scribble my notes all over it as I go along. I got Phoenix 5.5 and both the 7E and the 10 working with it. Now to finish my trex450 Dominator and figure out an ini for it.
This site is great.
Thanks to all involved.
John
This site is great.
John
- lkedmiston
25 Aug 2016 15:41 #53094
by lkedmiston
Replied by lkedmiston on topic DEVO 7E and 10 5.0 manual
Thanks guys, it never occurred to me to open it with Opera! The next question, however, this says ver 4.1-dev. Is this manual older than the one on the home page?
- Arnold
25 Aug 2016 17:06 - 25 Aug 2016 17:07 #53097
by Arnold
I believe it's just the cover has the wrong date & version. The last part of the installation section talks about version 5.0.
lkedmiston wrote: ..., this says ver 4.1-dev. Is this manual older than the one on the home page?
Last edit: 25 Aug 2016 17:07 by Arnold.
Time to create page: 0.401 seconds
- DEVO 7E and 10 5.0 manual
