Duplication model.ini
16 Aug 2016 17:07 #52818 by Morlacus
Duplication model.ini was created by Morlacus
Hello
I have experienced this with my devo 12s deviation 5.00 : the model.ini files for the 9th model and for the 18th one seem to be allways the same . If I reset the model 18, the model 9 is also erased .
If I copy a model to the 18, it is also copied to the 9
Has anybody an explanation ?
Thanks for any help.
Morlacus
17 Aug 2016 16:36 - 17 Aug 2016 16:38 #52839 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Duplication model.ini
Models 9 and 18 are totaly different on my 12s.
I got a 8s before and sometimes i got probs with the models. When this happed i erase all data and format the drive (no quick format). After that the problems gone. Save you models and all files before!
Last edit: 17 Aug 2016 16:38 by -=Hubi-Dirk=-.
18 Aug 2016 08:29 #52865 by Morlacus
Replied by Morlacus on topic Duplication model.ini
Thanks for your reply, -=Hubi-Dirk=-.
The formatting of my usb drive has cured my devo 12 S.
model.ini have a normal behaviour, no more duplication.
Problem solved
Best regards
19 Aug 2016 06:23 #52890 by -=Hubi-Dirk=-
Thats good to hear.
Happy flying ☺
Time to create page: 0.196 seconds
