Trim in the mixer output equation
29 Aug 2016 00:37 - 29 Aug 2016 00:45 #53224 by valley_nomad
Trim in the mixer output equation was created by valley_nomad
Hello, In the section 9.2.6 of current manual (v5.0) it states:
A given mixer can be considered to have the general form:
M(x) = if(Switch) { Src * Curve * Scale + Offset} else {0} + Trim
My question is: Does the Trim, once enabled, indeed always has the effect on that specific mixer output regardless of the trigger switch state of that mixer?
Last edit: 29 Aug 2016 00:45 by valley_nomad.
29 Aug 2016 07:31 #53232 by mwm
Replied by mwm on topic Trim in the mixer output equation
This is a trivial thing to test. Open a new model, change the first mixer to complex, 2 mixers, set them to use the same input, trim on on one and off on the other, and make the second one use a switch. Then hit the switch and see what happens.
To save you the trouble (I wanted to know), if a mixer is disable, it's trim isn't applied.
Time to create page: 0.287 seconds
