Deviation 5.0.0 - Issues with PC connection
17 Sep 2016 07:44 #53949 by Wanderer777
Deviation 5.0.0 - Issues with PC connection was created by Wanderer777
I just installed Deviation 5.0.0 on my Devo 10 and noticed that I can't use my FPV Simulator anymore - in both, analog (audio cable) mode and USB (Gamepad) mode.
If I use the Devo 10 as an USB Gamepad (USBHID) and open the joystick calibration on Windows 7 (64 Bit), the joystick movement is totally erratic and srewed up.
If I use the analog cable with my copter profile (DEVO protocol), SmartProPo also receives screwed up data and says "device not connected". The analog method worked perfectly with the original Devention firmware though.
