Lemon Sat RXs terrible rainge.
09 Oct 2016 12:39 #54746 by Deal57
Lemon Sat RXs terrible rainge. was created by Deal57
So the only thing that changed is the FC stopped supplying 3.3v? Have you ruled out a power-supply problem on the FC that might be affecting the signal from the sat as well as other FC logic? An FC with low voltage on 3.3v could have more than just a problem with the RX port.
09 Oct 2016 15:35 #54759 by Arakon
Replied by Arakon on topic Lemon Sat RXs terrible rainge.
The regulator may be outputting a "dirty" voltage that can cause tons of issues.
09 Oct 2016 16:28 #54762 by Cereal_Killer
Replied by Cereal_Killer on topic Lemon Sat RXs terrible rainge.
Can you test the sat on a different naze32 board or a main rx or do something to eleminate that specific naze as you've already ruled out the receiver as the problem? I would suspect the already known bad naze as being the source of your issue over the devo...
Time to create page: 0.388 seconds
