lost binding during flying
- luenma
10 Oct 2016 08:18 #54784
by luenma
lost binding during flying was created by luenma
I am using a Devo 8S with deviation v4.0.1. I have noted some times the binding was lost during flying in distances shorter than 300 m and with full power in the radio. I needed to re-start the radio and then they were biding again. I am wondering if it is a fault of the radio, receiver or firmware (I have not updated to v5 at the moment). Has anybody had the same problem?
Thanks.
Thanks.
10 Oct 2016 08:33 - 10 Oct 2016 08:37 #54786
Replied by vlad_vy on topic lost binding during flying
What protocol do you use? If it's Devo protocol with telemetry enabled, update to v5.0.0.
Last edit: 10 Oct 2016 08:37 by vlad_vy.
- luenma
10 Oct 2016 08:58 - 10 Oct 2016 09:00 #54787
by luenma
Replied by luenma on topic lost binding during flying
I am still using v4.0.1. I will update to v5.0.0, but I cannot check it again now, I need to wait for 2 or 3 weeks.
Last edit: 10 Oct 2016 09:00 by luenma.
- luenma
31 Oct 2016 11:07 #55548
by luenma
I have updated to the lastest firmware version, v5.0.0, but I have still the same problem. I would like to be sure if it is hardware problem or not,
31 Oct 2016 11:13 #55549
Can you provide more info? What protocol? Do you use fixed ID or not? Telemetry enabled or not? Any aditional RF modules?
- Thomas.Heiss
31 Oct 2016 11:52 #55550
by Thomas.Heiss
Replied by Thomas.Heiss on topic lost binding during flying
If DSMx: What receivers.
Come on Luenma, don't hide behind all those required informations.
Please give as much as informations at once as you can and don't let use ask / guess them. Otherwise your nose might be broken because we had to pull out all infos from it
- luenma
31 Oct 2016 19:15 #55570
by luenma
I don't have any additional RF module. I am using Devo receiver without telemetry and with Devo protocol. I use fixed ID. When binding is lost then I turn off the radio and turn on again and then the binding is ok again, but I do not need to re-start the receiver but only the radio.
Thanks for your help.
31 Oct 2016 19:50 #55573
Do you have telemetry disabled at protocol options? For Devo protocol telemetry enabled by default.
But, at any case, problem with telemetry enabled was fixed at v5.0.0.
- luenma
02 Nov 2016 16:08 #55619
by luenma
I am not using telemetry but I see I have telemetry enabled at protocol options. Do you think that can be the reason for this problem? I am going to change it to telemetry disabled and I will see if this problem happens again.
Time to create page: 0.148 seconds
- lost binding during flying
