lost binding during flying
10 Oct 2016 08:18 #54784 by luenma
lost binding during flying was created by luenma
I am using a Devo 8S with deviation v4.0.1. I have noted some times the binding was lost during flying in distances shorter than 300 m and with full power in the radio. I needed to re-start the radio and then they were biding again. I am wondering if it is a fault of the radio, receiver or firmware (I have not updated to v5 at the moment). Has anybody had the same problem?
Thanks.
10 Oct 2016 08:33 - 10 Oct 2016 08:37 #54786 by vlad_vy
Replied by vlad_vy on topic lost binding during flying
What protocol do you use? If it's Devo protocol with telemetry enabled, update to v5.0.0.
Last edit: 10 Oct 2016 08:37 by vlad_vy.
10 Oct 2016 08:58 - 10 Oct 2016 09:00 #54787 by luenma
Replied by luenma on topic lost binding during flying
I am still using v4.0.1. I will update to v5.0.0, but I cannot check it again now, I need to wait for 2 or 3 weeks.
Last edit: 10 Oct 2016 09:00 by luenma.
31 Oct 2016 11:07 #55548 by luenma
I have updated to the lastest firmware version, v5.0.0, but I have still the same problem. I would like to be sure if it is hardware problem or not,
31 Oct 2016 11:13 #55549 by vlad_vy
Can you provide more info? What protocol? Do you use fixed ID or not? Telemetry enabled or not? Any aditional RF modules?
31 Oct 2016 11:52 #55550 by Thomas.Heiss
Replied by Thomas.Heiss on topic lost binding during flying
If DSMx: What receivers.
Come on Luenma, don't hide behind all those required informations.
Please give as much as informations at once as you can and don't let use ask / guess them. Otherwise your nose might be broken because we had to pull out all infos from it ;)
31 Oct 2016 19:15 #55570 by luenma
I don't have any additional RF module. I am using Devo receiver without telemetry and with Devo protocol. I use fixed ID. When binding is lost then I turn off the radio and turn on again and then the binding is ok again, but I do not need to re-start the receiver but only the radio.
Thanks for your help.
31 Oct 2016 19:50 #55573 by vlad_vy
Do you have telemetry disabled at protocol options? For Devo protocol telemetry enabled by default.
But, at any case, problem with telemetry enabled was fixed at v5.0.0.
02 Nov 2016 16:08 #55619 by luenma
I am not using telemetry but I see I have telemetry enabled at protocol options. Do you think that can be the reason for this problem? I am going to change it to telemetry disabled and I will see if this problem happens again.
Time to create page: 0.071 seconds
