Bind devo7e with Dasmikro micro dsm2 receiver
16 Nov 2016 15:58 #55964 by secnpa
Thanks for the reply. I have tried every possible way. Set command then save and unplug.. Powering on with battery or through usb makes no difference in my case.
So as it stands the dasmikro RX is completely unresponsive to binding with both of my devos and the RX that came included with the micro quad seems to be defective.
16 Nov 2016 17:18 - 16 Nov 2016 17:32 #55966 by aMax
Since the rx dasmikro is a autobind receiver, there should be no ID or at least the standart ID in the field and only
the reinit command available. Should work similar to the WL911 receiver boards(flysky/ throttle must be completely down).
But if this receiver is a dud, you better get in contact with the customer service soon.
Last edit: 16 Nov 2016 17:32 by aMax.
Time to create page: 0.106 seconds
