- 7e Fmod and Hold switch not working separately
- Zaphod
30 Oct 2016 09:36 #55515
by Zaphod
7e Fmod and Hold switch not working separately was created by Zaphod
Hi all,
Father in law's 7e has Deviation 5 and a 3 in 1 module installed.
Today I was setting it up to fly one of his helis and I noticed that in the mixer if I switch to Fmod1 the Hold1 comes on in the mixer.
Go to the main screen, flick to Hold1 and Fmod1 shows. The switches seem to be both acting as the Hold switch rather than independently.
Any suggestions? Wiring issue on the actual switches?
Might be a good time to upgrade and add more switches
- HappyHarry
30 Oct 2016 11:17 - 30 Oct 2016 11:18 #55519
by HappyHarry
Replied by HappyHarry on topic 7e Fmod and Hold switch not working separately
if this is a stock 7e then it surely must be set to do this in the mixer.
Last edit: 30 Oct 2016 11:18 by HappyHarry.
- Deal57
30 Oct 2016 14:20 #55522
by Deal57
Replied by Deal57 on topic 7e Fmod and Hold switch not working separately
In the transmitter menu, under channel monitor, hit the right arrow and check the input monitor. This should display exactly what your hardware thinks is happening, before the mixer is applied. If it is wrong there, you may have some crossed wires.
- Zaphod
31 Oct 2016 09:50 #55546
by Zaphod
Replied by Zaphod on topic 7e Fmod and Hold switch not working separately
Thanks guys. I'll pop around to see him and see what's happening.
Time to create page: 0.113 seconds
