Problem Adding 2x 3-way switches to devo 7e
31 Oct 2016 16:01 - 31 Oct 2016 16:33 #55563 by joelones
Hi Guys,
Kind of freaking out here...
I've added the 3x2 switched, started the devo and now no buttons appear to work. I'm using 1N4004 diodes and made the modification in the hardware.ini file. I have included some pictures.
imgur.com/a/XbB3Z
Add ideas what I could have screwed up?
EDIT: Found the problem, was shorting a wire. Please disregard.
Last edit: 31 Oct 2016 16:33 by joelones.
04 Nov 2016 09:37 #55659 by Fernandez
Replied by Fernandez on topic Problem Adding 2x 3-way switches to devo 7e
For the serious modders of devo 7e and if you like more switches/pot's in a compact TX, I can give full credit to the Slipstream modification U7E, 256k CPU and HappyHarry's U7E builds. In use for long time now many flights it is stable no problems!
My 7e is equipped with, 2x Pots, 2x3Way Switch and 6x2Way Switch, but you can define and install your own switch setup to your preference. such as 4x3way 2x2way etc.
www.deviationtx.com/forum/how-to/5824-ul...-way-switch?start=60
Time to create page: 0.706 seconds
