Devo 10 Deviation install help
- DocSampson
18 Nov 2016 04:51 #55995
by DocSampson
Devo 10 Deviation install help was created by DocSampson
Hey guys,
Finally got a Devo 10 (white model) and wanted to install Deviation. Followed multiple tutorials but I keep getting stuck on the same part. After using the dfuse tool and installing the Deviation dfu file my tx will not go to usb mode (ent + power) and any text on the screen is garbled in the menus or pop-ups. I am typing this from my phone so I'm sorry that this is limited. I've tried now on 2 different machines. Each time I get that the tx was recognized and each time it says the flash was successful. While in update mode (ext + power) my computer recognizes the transmitter as STM followed by numbers. I have been at it for a day now and I'm getting a bit frustrated.
Hope this great community can help.
- Arnold
18 Nov 2016 19:11 - 18 Nov 2016 20:02 #56011
by Arnold
Replied by Arnold on topic Devo 10 Deviation install help
Could be a Windows driver issue.
I recommend you read the official deviation installation instructions in the Devo 10 user manual, which you can find in the sidebar on the left side of this page.
Last edit: 18 Nov 2016 20:02 by Arnold.
18 Nov 2016 21:35 #56019
Replied by hexfet on topic Devo 10 Deviation install help
Does your ENT button work reliably? On my 10 it's a bit iffy.
The times I've seen garbled characters there's been a problem reading from the filesystem so that's consistent with the problem you're having.
If it seems like deviation is running but just showing garbled screens you could try navigating to the USB screen and enabling it that way. Use the emulator to determine the button presses to get there. If your ENT button is having issues that should become clear because you won't be able to navigate the menu.
- DocSampson
18 Nov 2016 23:06 #56023
by DocSampson
Replied by DocSampson on topic Devo 10 Deviation install help
through the garbled text i can tell that it has not taken the deviation file. it still shows devention on start up.
19 Nov 2016 03:43 #56028
That's a different kettle of fish. Sounds like the install at least wrote enough memory to corrupt the text?
Have you tried more than one usb cable?
Try the deviation install tool to see if it has more success.
Try flashing the devention firmware to see if that works.
- DocSampson
19 Nov 2016 07:22 #56037
by DocSampson
Here is where it all gets crazy. I rechecked today. When I use dfuse I can restore the library to get the text back. Turns out it is the devention install tool which corrupts the text. I'm currently on .8A
- DocSampson
21 Nov 2016 05:15 #56122
by DocSampson
Sorry for the double post,
So it seems that i can change my library but my TX is stuck at .8A. ive tried flashing .8b and .4a. no luck
- DocSampson
28 Nov 2016 06:40 #56338
by DocSampson
bump?
Time to create page: 0.117 seconds
- Devo 10 Deviation install help
