simple way to check if burned module devo 7e
28 Nov 2016 10:08 #56340 by kaligola
hi, i did range mod on my devo 7e but unfortunately i usend to play binding and setting model with quadcopter connected in cleanflight without antenna, now seems to have poor range is there a simple measurement to do to check this, a multimeter to check on antenna connector or something else?
10 Jan 2017 15:31 #57793 by kaligola
Replied by kaligola on topic simple way to check if burned module devo 7e
solved, dismantled antenna and module was the wire to sma connector that was damaged by hot kind of glue used to fix in place.does not was other than this anyway i yet ordered new module and used this
Time to create page: 0.106 seconds
