Devo 7e Fmod and Hold working as one
- Zaphod
01 Jan 2017 02:15 #57410
by Zaphod
Devo 7e Fmod and Hold working as one was created by Zaphod
I'm currently working on Dad's 7e and fitted a 3 in 1 module. All the solder joints look good (including the MPU one) but now I find that when I switch the Fmod from 0 to 1 it triggers the Hold switch as well.
I've made a simple model file and put Fmod on ch5 and Hold on ch6 using max/min so each switch should read either +100 or -100. However it doesn't matter which switch I use both channels do the same as if there was only 1 switch. Both channels move to either +100 or -100 at the same time.
I've removed the 3 in 1 module but the switches are still not independent of each other.
Would adding the module cause this or is it a hardware fault with the tx itself? Where would I look on the main board to check? How would I check?
Working on the 7e really makes me love my 10!
- Cereal_Killer
01 Jan 2017 14:47 #57419
by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7e Fmod and Hold working as one
Please post your Hardware.ini file.
My first thought if you've accidentally enabled aftermarket switches in your HW file, if that's not it the ONLY other option is that you've shorted the two inputs.
Time to create page: 0.048 seconds
- Devo 7e Fmod and Hold working as one
