Devo F12E 4in1 Modul
05 Jan 2017 12:05 #57549 by dustin_84
Devo F12E 4in1 Modul was created by dustin_84
Hi, has any one a picture how to install the 4in1 Module into a Devo F12E?
thanks
markus
05 Jan 2017 15:52 #57552 by dado099
Replied by dado099 on topic Devo F12E 4in1 Modul
You don't have the best devo to deviate it with a 4in1.
Please condider f12e is only partially supported and seems to have a lot of problems with deviation.
I have seen in the past test builds for it, but you have to search on the forum to find them.
Good luck !
06 Jan 2017 03:30 #57573 by Artus
Replied by Artus on topic Devo F12E 4in1 Modul
My F12E is working well with deviation :)
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
06 Jan 2017 10:34 #57587 by dado099
06 Jan 2017 20:30 #57600 by victzh
Replied by victzh on topic Devo F12E 4in1 Modul
Mine also have this problem. What version of Deviation do you use? There may be several hardware versions, different enough to not work with video. Or may be we introduced some bug in between.
Also, do you know hardware version of your F12E?
08 Jan 2017 14:00 #57701 by Bonemyster
Replied by Bonemyster on topic Devo F12E 4in1 Modul
Im using the 12/23/2016 version of the devo f12e deviation firmware and the fpv does not work. I've used past versions since november and none of them have the fpv working. If anyone has a working fpv version then please let upload your version. The f12e is only in the nighties so I'm guessing it's relatively new compared to the others.
08 Jan 2017 14:03 #57702 by Bonemyster
The same pinouts you use for the devo 10 you can use for the devo f12e.
09 Jan 2017 07:08 #57732 by victzh
It is new and raw. I only recently got my F12E, and as early experiments of PB shown there are several hardware versions, at least two, and they have slightly different initialization parameters for the video chip.
09 Jan 2017 08:02 #57735 by Bonemyster
Yea ive seen 2 devo f12es, the white one with the black top and the black one with the silver top. I have the white one with the black top and my friend has the black one with the silver top. Both of us have experienced the same problem
  • SeekerOfYaw
  • SeekerOfYaw's Avatar
  • FPV The Planet !!!
18 Feb 2017 09:24 - 19 Feb 2017 01:00 #59274 by SeekerOfYaw
Replied by SeekerOfYaw on topic Devo F12E 4in1 Modul
dustin_84 wrote: Hi, has any one a picture how to install the 4in1 Module into a Devo F12E?
thanks
markus
Seems Nightly is "fairly stable" as of 1-23-17... Been Following 5 threads in Deviation for a year, Tons of Struggle/Teamwork/Conquering for this Tx! Anyway, here is my attempt at F12E Deviation & 4-in-1 install...I'm stuck at step G below...please reprimand me where necessary...
A) Deviating the F12E seems to have worked flawlessly. The Walkera F-series transmitters have a VERY small Flash space(46KB). :P Too small for the traditional FAT file system used by Deviation for other Walkera transmitters. Instead a custom "Nightly" file system was designed for these cases called 'DevoFS' The file system installation is different because of this. No need/Unable to install multiple files like normal Deviation...just 1 tidy innovative file...Wiki recommended using Walkera DfuSe Tool & all seemed well except Win7 would not recognize Tx as an external drive and Tx was stuck in USB Mode even after reboot?... Deviation Uploader & Driver worked instantly!... Maybe too soon to tell but it Seems the Bugs: 'FPV stops working after Deviation' & 'Models erase after power off' have been resolved!?!? Just Sayin'...Now to install the 4-in-1 Module! *(Champion vlad_vy posted today in Development & Builds: Ultimate F12E Memory Mod!!! ;))
B ) Pre-Soldered wires before install...
C) Remove antenna, 2 top screws, and rock board side to side while lifting to remove stock module from pin sockets...
D) Mount & Secure 4-in-1 & re-secure antenna...
E) Soldered 2500 wire to TCK (A14)... 7105 wire to TMS (A13)
F) Holy...Son of a...Mother... There are NO accommodating pads to solder the 2401 wire to... It will need to be soldered to a pin leg of the MCU :P Apparently We have a choice of 2 pins: PB3/Pin 89(B3 ) OR PB10/Pin 47(B10)...neither of which end at a nice little copper hole... *Notice: If Pin 89 is used it must be enabled/assigned as "B3 " A space MUST be entered after the B3 or a glitch will occur causing your models NOT to be saved at power off !!! ;)
G) ANY secret workaround soldering locations would be greatly appreciated lol...or ANY advice on HOW Artus was able to solder such a small connection super CLEAN like this in photo 'G'
H) The MCU installed in your F12E is actually upside-down compared to figure H below... pin 47 is on top 4th from the left & pin 89 is on bottom 12th from the right... just saying
Last edit: 19 Feb 2017 01:00 by SeekerOfYaw.
18 Feb 2017 17:36 #59287 by Deal57
Replied by Deal57 on topic Devo F12E 4in1 Modul
Nice work! This should certainly answer a lot of questions.
As to soldering on the processor, yeah, the pins are really tiny. Use Kapton tape to mask off the pins next to the one you want. IMO this tape is essential in soldering tiny parts. Once masked, you can see in the photo that positioning the wire first (after properly tinning the end!) over the MCU, most people find the wire stays in place while applying the solder.
And the best advice ever given to me... practice on an old board first. I have a few toy transmitter boards that have served me well for solder training!
  • SeekerOfYaw
18 Feb 2017 18:48 #59290 by SeekerOfYaw
Kapton tape and proper (lightly tinned) preparation sounds Brilliant... Thank You!
  • SeekerOfYaw
19 Feb 2017 00:20 #59296 by SeekerOfYaw
Got It!... used pin 89 (B3 )... continuity from 89 to 2401 on module... open from 89 to 88 & 90... Off Topic BUT I also added a JST out the bottom with Lipo V & Female RCA w/ FPV vid signal to accommodate cheap passenger FPV goggles
19 Feb 2017 02:58 #59300 by Deal57
Nice!
04 Mar 2020 00:58 #75988 by Yon
Replied by Yon on topic Devo F12E 4in1 Modul
Hello, what version of firmware is suitable for this 4in1 module. I have followed these instructions but I tried to bind eachine E011.
My devo F12E hardware is V 1.0 & Firmware V 1.3A
04 Mar 2020 04:11 #75989 by vlad_vy
Replied by vlad_vy on topic Devo F12E 4in1 Modul
You can use any Deviation nightly build. Devo F12E supported with nightly builds only.
04 Mar 2020 22:51 #75998 by Yon
I tried flashing the firmware with nightly build. but I have trouble connecting my devo F12E with the compiler. usb like not detected.
is there a way from the beginning to try to reinstall the firmware to be able to use the 4in1 module.
thank you very much for the answer.
05 Mar 2020 03:50 - 05 Mar 2020 03:56 #76001 by vlad_vy
Most likely it's problem with driver. Windows version? Do you use Dfuse USB Upgrade Tools v2.31? Do you try different USB cable?
Probably will be better for Devo F12E use Deviation Uploader.
www.deviationtx.com/manuals/html-devo10-en/ch_install.html
Also, match more reliable and convenient to use will be Devo F12E with flash memory mod:
www.deviationtx.com/forum/builds/6861-ul...-devof12e-xms-builds
Last edit: 05 Mar 2020 03:56 by vlad_vy.
05 Mar 2020 05:18 #76004 by Yon
After I tried again it turned out that it was really just a problem with the driver.
devo I succeeded in Dfuse. then I flash with firmware v.5.0.0-ac7f63e using the Dfuse 2.31 upgrade tool & found a problem. the monitor screen is just written "Deviation USB".
I was curious to try to flash again with the dfuse 3.0.5 upgrade tool. "Upgrade Program" without having to restore the button.
what should I do to move to a normal position.
Please help
05 Mar 2020 05:31 - 05 Mar 2020 05:35 #76005 by vlad_vy
Do not use Dfuse 3.0.5, you can damage transmitter bootloader, it's demo version Dfuse, not Walkera Dfuse.
Try write to transmitter USB drive "devo.fs" file from firmware archive.
To use 4in1 module you will need to edit "hardware.ini" file inside ""devo.fs" file. It's not trivial task, search the forum for help.
Last edit: 05 Mar 2020 05:35 by vlad_vy.
Time to create page: 0.428 seconds
