Devo F12E 4in1 Modul
05 Mar 2020 09:12 #76011 by Yon
Replied by Yon on topic Devo F12E 4in1 Modul
I did the wrong procedure
tell me the link how to return the devo F12E to its normal position?
05 Mar 2020 09:46 - 05 Mar 2020 10:18 #76013 by vlad_vy
Replied by vlad_vy on topic Devo F12E 4in1 Modul
If you can't get DFU mode (firmware upgrade mode, EXT + Power On), probably you damaged bootloader.
1) You need bootloader file for Devo F12E - "devof12ebootloader.bin"
www.deviationtx.com/downloads-new/catego...nsmitter-bootloaders
2) You need flash bootloader. I don't know how do it with Devo F12E, but for Devo 7e:
silpstream.com/103/ultimate7e-flashing-the-bootloader/
www.deviationtx.com/forum/6-general-disc...-7e-bootloader#34250
connect "RESET" on the Tx to pin 15 (NRST) on the stlink
connect "TMS" on the Tx to pin 7 (TMS) on the stlink
connect "TCK" on the Tx to pin 9 (TCK) on the stlink
connect "GND" on the Tx to pin 20 (GND) on the stlink
connect "Vdd" (3.3V) on the Tx to pin 1 (Vcc) on the stlink
connect MCU BOOT0 (pin 94) to 3.3V (with 1K resistor, first check if pin 94 is not connected to GND).
For the 10pin st-link the connections are:
tms > swdio
tck > swclk
gnd > gnd
vdd > 3.3V
Be sure not to use the st-link 5V line as it will damage the mcu
Power bypass points, 2 pads to the right from "DC IN" connector:
Last edit: 05 Mar 2020 10:18 by vlad_vy.
06 Mar 2020 01:28 #76019 by Artus
Replied by Artus on topic Devo F12E 4in1 Modul
Yon wrote: After I tried again it turned out that it was really just a problem with the driver.
devo I succeeded in Dfuse. then I flash with firmware v.5.0.0-ac7f63e using the Dfuse 2.31 upgrade tool & found a problem. the monitor screen is just written "Deviation USB".
I was curious to try to flash again with the dfuse 3.0.5 upgrade tool. "Upgrade Program" without having to restore the button.
what should I do to move to a normal position.
Please help
as i know this is normal you have only to format the usb and copy the "rest" to the drive
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
06 Mar 2020 02:34 #76020 by Yon
Yes, I returned it to normal. I re-flash with dfuse 2.31 & firmware 1.5A.
Can I still reinstall the firmware so that it can support the 4in1 module. which version of firmware & nightly build to make installation easy using dfuse 2.31 without any failure on the screen, only "Deviation USB" appears.
06 Mar 2020 03:26 #76021 by Artus
yes and have you tried to format the usb hd in your f12e to format ?
06 Mar 2020 04:10 - 06 Mar 2020 04:16 #76022 by vlad_vy
You can't format Devo D12E USB drive, it has fixed format.
After flashing Deviation firmware with Dfuse 2.31, reboot transmitter, you will get "Deviation USB" screen, then copy to transmitter USB drive "devo.fs" file from firmware archive and reboot transmitter. Without this file you will always get "Deviation USB".
Last edit: 06 Mar 2020 04:16 by vlad_vy.
06 Mar 2020 05:58 #76024 by Yon
Right. the screen is always "USB deviation". After that what should I do step by step to complete the nightly build firmware installation.
06 Mar 2020 06:47 #76025 by vlad_vy
Flash Deviation firmware with Dfuse 2.31, reboot transmitter, you will get "Deviation USB" screen, then copy to transmitter USB drive "devo.fs" file from firmware archive and reboot transmitter.
06 Mar 2020 10:17 #76027 by Yon
It seems that there is already a "devo.fs" file. reads on a computer / laptop in drive G. & After I reboot it still says USB deviation on the screen.
06 Mar 2020 10:40 - 06 Mar 2020 10:41 #76028 by vlad_vy
Do you try to rewrite this file? It can be damaged or empty. Try rewrite USB drive "devo.fs" file with "devo.fs" file from firmware archive.
Last edit: 06 Mar 2020 10:41 by vlad_vy.
06 Mar 2020 13:57 #76033 by Yon
Okay, I will try to insert the file "devo.fs" from the firmware zip file after extracting it into the USB deviation
07 Mar 2020 00:40 #76036 by Yon
thank you very much, I was able to replace the firmware with nightly build v.5 by deleting the devo.fs file on the usb drive & replacing it with the existing devo.fs file in the firmware folder after extracting.
I will try to connect with eachine e011 & other receivers that support the 4in1 module.
if there is a problem I will give news here.
07 Mar 2020 06:02 #76037 by vlad_vy
You will need "BuildFS.exe" to extract, edit "hardware.ini" and create a new devo.fs:
Usage of buildfs.exe is inside buildfs.zip file:
www.deviationtx.com/downloads-new/category/3-miscellaneous
07 Mar 2020 13:49 #76041 by Yon
How to use ?
is there any ready-made firmware without having to change existing files such as "hardware.ini" to be able to connect all receivers in this 4in1 module.
I tried it but none of them can connect with my devo F12E which has installed the 4in1 module with firmware nightly build V.5.0.0
Time to create page: 0.394 seconds
