Nightly builds
13 Jan 2017 10:04 #57878
Nightly builds was created by vlad_vy
It looks like Nightly builds stop working.
- Cereal_Killer
13 Jan 2017 13:16 - 13 Jan 2017 13:18 #57885
by Cereal_Killer
Replied by Cereal_Killer on topic Nightly builds
Why do you say that? Cause there hasn't been a new one since 1/5? They only build if commits have been pushed*
*has that happened? If so they could very well be broke... I'm not sure if anything been pushed recently since the 5th...
Edit: Travis status is good, are you sure any thing's been pushed since 1/5?
Last edit: 13 Jan 2017 13:18 by Cereal_Killer.
13 Jan 2017 13:24 #57887
Replied by vlad_vy on topic Nightly builds
Merged about 13 hours ago
and
Merged 3 days ago
So, skipped two nightly builds.
and
Merged 3 days ago
13 Jan 2017 13:48 #57888
Replied by hexfet on topic Nightly builds
Looks like the F4 build is failing. Travis doesn't check that one but it is in the nightly build. Will have a look tomorrow if someone else doesn't get there first.
13 Jan 2017 14:04 - 13 Jan 2017 14:30 #57890
I don't think it is a case. Some time ago AT9 build was not checked and nightly build started, but failed for AT9 with error.
travis-ci.org/DeviationTX/deviation/builds/185102080
Last edit: 13 Jan 2017 14:30 by vlad_vy.
13 Jan 2017 15:11 - 13 Jan 2017 15:13 #57893
By the way, merged "Pull Request #95 Devo F7 input" defines 6 switches, but Devo F7 has 5 switches only.
Last edit: 13 Jan 2017 15:13 by vlad_vy.
14 Jan 2017 10:10 #57932
Today Nightly build started, but failed for Devo F4. It's better than nothing.
19 Mar 2018 11:44 #68206
21 Mar 2018 10:16 #68241
I think we need reload build script.
- Bisky
22 Mar 2018 14:37 #68273
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic Nightly builds
And I wonderd why there is no new nightly....
- Moeder
22 Mar 2018 18:16 #68288
by Moeder
Replied by Moeder on topic Nightly builds
Nightly builds are API triggered externally, because when Travis was first implemented it didn't feature cron tasks. As everything was working fine, we didn't change this behavior. Something seems to be wrong with this, so it is up to FDR to fix this. Haven't heard from him in a couple of days, I guess I could do a quick fix to bridge the problem...
- Moeder
22 Mar 2018 20:53 #68297
by Moeder
Allright, nightlies are building everyday for now. We'll sort the details out when FDR is with us again. We might just stick with the cron job, as it is easier to maintain.
28 Mar 2018 10:09 #68383
Now we havn't nightly builds history, all builds are the same.
- Moeder
28 Mar 2018 11:18 #68384
by Moeder
What do you mean? The fact that daily nightlies are built although no new commits are made? Or is anything else wrong? I could add a check for the timestamp of the latest commit and only submit the build if it is less than 24h old.
28 Mar 2018 11:22 #68385
The fact that daily nightlies are built although no new commits are made.
- ajtank
30 Mar 2018 01:51 #68414
by ajtank
Replied by ajtank on topic Nightly builds
The builds for 28/3 and 29/3 carry the same revision 04f8983. So are they actually identical? Thanks.
- Moeder
30 Mar 2018 06:06 #68419
by Moeder
Yes, they are identical.
09 Nov 2018 10:10 #71666
I think we can remove CRON entry at travis.yml. PB updated install_nightlies.tar.enc and travis.yml, and now Nightly Builds can start normally.
- Moeder
09 Nov 2018 19:48 #71683
by Moeder
You are right, I removed the cron job.
- ltwvince
27 Jul 2019 05:12 #74805
by ltwvince
Replied by ltwvince on topic Nightly builds
Hi guys,
Not sure if you all aware that the currently nightly builds had stop since 09-Jun-2019 as I was looking for newer build.
Thanks.
Thanks.
Time to create page: 0.123 seconds
- Nightly builds
