Nightly builds
13 Jan 2017 10:04 #57878 by vlad_vy
Nightly builds was created by vlad_vy
It looks like Nightly builds stop working.
13 Jan 2017 13:16 - 13 Jan 2017 13:18 #57885 by Cereal_Killer
Replied by Cereal_Killer on topic Nightly builds
Why do you say that? Cause there hasn't been a new one since 1/5? They only build if commits have been pushed*
*has that happened? If so they could very well be broke... I'm not sure if anything been pushed recently since the 5th...
Edit: Travis status is good, are you sure any thing's been pushed since 1/5?
Last edit: 13 Jan 2017 13:18 by Cereal_Killer.
13 Jan 2017 13:24 #57887 by vlad_vy
Replied by vlad_vy on topic Nightly builds
Merged about 13 hours ago
and
Merged 3 days ago
So, skipped two nightly builds.
13 Jan 2017 13:48 #57888 by hexfet
Replied by hexfet on topic Nightly builds
Looks like the F4 build is failing. Travis doesn't check that one but it is in the nightly build. Will have a look tomorrow if someone else doesn't get there first.
13 Jan 2017 14:04 - 13 Jan 2017 14:30 #57890 by vlad_vy
I don't think it is a case. Some time ago AT9 build was not checked and nightly build started, but failed for AT9 with error.
travis-ci.org/DeviationTX/deviation/builds/185102080
Last edit: 13 Jan 2017 14:30 by vlad_vy.
13 Jan 2017 15:11 - 13 Jan 2017 15:13 #57893 by vlad_vy
By the way, merged "Pull Request #95 Devo F7 input" defines 6 switches, but Devo F7 has 5 switches only.
Last edit: 13 Jan 2017 15:13 by vlad_vy.
14 Jan 2017 10:10 #57932 by vlad_vy
Today Nightly build started, but failed for Devo F4. It's better than nothing.
19 Mar 2018 11:44 #68206 by vlad_vy
21 Mar 2018 10:16 #68241 by vlad_vy
I think we need reload build script.
22 Mar 2018 14:37 #68273 by Bisky
Replied by Bisky on topic Nightly builds
And I wonderd why there is no new nightly....
Devo F7 XMS + 4in1 module
22 Mar 2018 18:16 #68288 by Moeder
Replied by Moeder on topic Nightly builds
Nightly builds are API triggered externally, because when Travis was first implemented it didn't feature cron tasks. As everything was working fine, we didn't change this behavior. Something seems to be wrong with this, so it is up to FDR to fix this. Haven't heard from him in a couple of days, I guess I could do a quick fix to bridge the problem...
22 Mar 2018 20:53 #68297 by Moeder
Allright, nightlies are building everyday for now. We'll sort the details out when FDR is with us again. We might just stick with the cron job, as it is easier to maintain.
28 Mar 2018 10:09 #68383 by vlad_vy
Now we havn't nightly builds history, all builds are the same.
28 Mar 2018 11:18 #68384 by Moeder
What do you mean? The fact that daily nightlies are built although no new commits are made? Or is anything else wrong? I could add a check for the timestamp of the latest commit and only submit the build if it is less than 24h old.
28 Mar 2018 11:22 #68385 by vlad_vy
The fact that daily nightlies are built although no new commits are made.
30 Mar 2018 01:51 #68414 by ajtank
Replied by ajtank on topic Nightly builds
The builds for 28/3 and 29/3 carry the same revision 04f8983. So are they actually identical? Thanks.
30 Mar 2018 06:06 #68419 by Moeder
Yes, they are identical.
09 Nov 2018 10:10 #71666 by vlad_vy
I think we can remove CRON entry at travis.yml. PB updated install_nightlies.tar.enc and travis.yml, and now Nightly Builds can start normally.
09 Nov 2018 19:48 #71683 by Moeder
You are right, I removed the cron job.
27 Jul 2019 05:12 #74805 by ltwvince
Replied by ltwvince on topic Nightly builds
Hi guys,
Not sure if you all aware that the currently nightly builds had stop since 09-Jun-2019 as I was looking for newer build.
Thanks.
Time to create page: 0.096 seconds
