Emulator build failed
18 Jan 2017 16:49 - 18 Jan 2017 16:50 #58131 by vlad_vy
Emulator build failed was created by vlad_vy
After PR #98 "faster byte reverse for xn297 routines" I can't build emulators with my Windows build environment, I have the error:
 + Compiling 'protocol/spi/nrf24l01.c'
protocol/spi/nrf24l01.c:306:30: error: "__ARM_ARCH_ISA_THUMB" is not defined [-Werror=undef]
cc1.exe: some warnings being treated as errors
make: *** [objs/emu_devo8-w32/nrf24l01.o] Error 1
What is wrong with my build environment?
Last edit: 18 Jan 2017 16:50 by vlad_vy.
19 Jan 2017 04:35 #58163 by vlad_vy
Replied by vlad_vy on topic Emulator build failed
Will be fixed in Nightly builds, if pull request will be approved.
-#if ( defined (__GNUC__) && (__ARM_ARCH_ISA_THUMB==2) )
+#if ( defined (__GNUC__) && defined (__ARM_ARCH_ISA_THUMB) && (__ARM_ARCH_ISA_THUMB == 2) )
19 Jan 2017 05:19 #58166 by victzh
Replied by victzh on topic Emulator build failed
Your compiler is GNU C, but __ARM_ARCH_ISA_THUMB is not defined. I'll fix it in a sec.
19 Jan 2017 07:32 - 19 Jan 2017 07:33 #58167 by vlad_vy
After PR #105 "Filesystem for the emu_devo12e" I can't build emulator for devo12e with my Windows build environment, I have infinite number of 3 lines:
print() on closed filehandle $fh at ../utils/font/bdf_to_font.pl line 232.
print() on closed filehandle $fh at ../utils/font/bdf_to_font.pl line 233.
print() on closed filehandle $fh at ../utils/font/bdf_to_font.pl line 234.
Last edit: 19 Jan 2017 07:33 by vlad_vy.
19 Jan 2017 07:58 #58169 by FDR
Replied by FDR on topic Emulator build failed
Strange, because I could build it yesterday on Windows as well.
I'll take a look when I'll get home.
Without that mod the 12e filesystem only contained the models directory...
I've got my 12E just before Xmas, but only now started to care about it, because I had no time for that.
Yesterday I loaded deviation on it, but realised, that the filesystem is missing the language directory.
It behaved strangely on the main page config, so I wanted to try that in the emulator, when I saw that it misses almost the whole filesystem.
I built with my changes, and I could start the emulator, however the screen was too small, which you've already corrected, but the buttons used are wrong too, so it is still not usable...
Vlad, do you have a 12E too?
19 Jan 2017 08:01 #58170 by vlad_vy
No, but emulator buttons fixed also. See my next pull request.
19 Jan 2017 08:02 #58171 by FDR
Thank! :)
I'll try that too...
19 Jan 2017 08:43 - 19 Jan 2017 08:45 #58173 by vlad_vy
With my proposed changes for PR #105 "Filesystem for the emu_devo12e" the devo12e emulator builds and works fine. I think it's the right way, all other emulators do the same.
Last edit: 19 Jan 2017 08:45 by vlad_vy.
19 Jan 2017 14:04 #58189 by vlad_vy
Pull request with fix has been sent.
19 Jan 2017 16:51 #58195 by FDR
vlad_vy wrote: No, but emulator buttons fixed also. See my next pull request.
Merged.
19 Jan 2017 16:52 #58196 by FDR
vlad_vy wrote: Pull request with fix has been sent.
Merged too...
Time to create page: 0.588 seconds
