Devo F7 Nightly Build + Qr X350 Pro Model Help
30 Jan 2017 20:06 - 30 Jan 2017 20:25 #58572 by Dustalot
I recently upgraded my Devo F7 to deviation nightly build 1/20/17. After I arm the motors spin up right away then hold high rpm for a few seconds even after dropping throttle to 0. Then I have to re arm and I get motor response after about 15% throttle. When I calibrate the ESC's the throttle works fine. There is not enough space left on the transmitter to import any models. Does anyone know how to add the parameters for the X350 pro into the F7? I read somewhere I may need to pick apart a build file and add the model I need to the .fs file and re-import. I'm just not quite sure how to do that. My stock Devo 7 is behaving normal. Smooth throttle all the way through.
Last edit: 30 Jan 2017 20:25 by Dustalot. Reason: Update after testing
30 Jan 2017 20:39 - 30 Jan 2017 22:27 #58575 by Arnold
For information about working with a devo.fs file, take a look at this post from another thread:
www.deviationtx.com/forum/6-general-disc...protocol-files#57528
<Edit> Conversation about the "devo.fs" portion of this post is continued in the above thread.
Last edit: 30 Jan 2017 22:27 by Arnold.
Time to create page: 0.114 seconds
