Help needed with lcd display devo 7e
03 Feb 2017 17:55 - 03 Feb 2017 21:09 #58703 by slim
Hi guys:
I'm new here as a writer, but not as a forum reader.English is not my language, sorry for any mistake and many thanks to all for your teachings and for that wonderful piece of software called deviation.
My problem is, in essence, my fault for not doing things right, but that's life.
I am the owner of a 7e devo and when desoldering the original CYRF module I have destroyed some connections associated with it on the motherboard.
To try to fix it, I desoldered the lcd screen and when I have soldered it again, does not work.
The rest of the transmitter works perfectly, but the display does not (as seen in the image).
I think: "with the heat I've damaged the lcd screen", but I'm not totally sure about this as it could also be the MCU.
Since I do not have much money, I would like to repair it and continue learning, because they are not very expensive spare parts.
The original LCD has 18 pins, two for power, two for the backlight LED, one RST and the rest of the used go directly to the MCU.
I have looked for displays 128 * 64 on ebay and this one is very similar:
www.ebay.es/itm/Display-Grafico-LCD-KS01...sGLLBFF59aCXH4uIEMkQ
Fabricante: Goldentek.
Modelo: GG-1206P0-GSL6-A.
Píxeles: 128 x 64.
Iluminación: Verde.
Controlador: KS0108 o compatible.
Cable plano FFC incluido de 134 x 21 mm.
Nº de contactos: 20.
Voltage de operación: 5 Voltios.
Voltage de iluminación LED: 4,5 Voltios.
Voltage de contraste: - 4,2 Voltios.
Dimensiones: ancho 63,30 x alto 52,25 x fondo 10,3 mm.
Peso: 41 Gr.
Pin 1: VDD Supply voltage for logic (+5V).
Pin 2: VSS Ground (0V).
Pin 3: V0 Voltaje negativo para contraste del LCD (- 4,2 Voltios).
Pin 4: DB0 Data bus.
Pin 5: DB1 Data bus.
Pin 6: DB2 Data bus.
Pin 7: DB3 Data bus.
Pin 8: DB4 Data bus.
Pin 9: DB5 Data bus.
Pin 10: DB6 Data bus.
Pin 11: DB7 Data bus.
Pin 12: CS2 Select segments 65-128.
Pin 13: CS1 Select segments 1-64.
Pin 14: RESET Reset the LCD module.
Pin 15: R/W H: Read data, L: Write data.
Pin 16: C/D L: Command, H: Data.
Pin 17: E Enable signal.
Pin 18: Sin funcion.
Pin 19: Anodo Led (+ 4,3 Voltios).
Pin 20: Catodo Led Ground (0V).
I have also seen some post in the forum to replace the screen with an oled, but that is too much for my knowledge.
I really appreciate any help.
Last edit: 03 Feb 2017 21:09 by slim.
04 Feb 2017 03:59 - 04 Feb 2017 04:28 #58726 by ajtank
Replied by ajtank on topic Help needed with lcd display devo 7e
According to the thread here , it seems a different LCD from the one on eBay.
If tvs20 is correct, the correct LCD is using the controller UC1601. You may test your LCD to ensure it is defective before looking for a new replacement.
Last edit: 04 Feb 2017 04:28 by ajtank.
07 Feb 2017 19:31 - 07 Feb 2017 22:54 #58879 by slim
Replied by slim on topic Help needed with lcd display devo 7e
Thank you very much, ajtank, for such extensive information. As you say, the ldc controller of devo 7e is UC1601 which, unfortunately, is not easy or cheap to get.
I also have no way to check the one I have, but I have returned to the original firm devention and I have reinstalled the original libraries and the result has been similar: points without order on the screen, although placed in different places.
I imagine the signals from the MCU arrive to the lcd, but the screen interprets them chaotically.
When desoldering it I suppose that it has received more heat than the one that supports and that is why it has failed since between the exit of the MCU and the entrance of the lcd there are no electronic components.
I have seen that it is possible to replace the lcd with a 4-pin oled display:
www.ebay.es/itm/Display-OLED-0-96-Blanco...d:g:FjAAAOSwgZ1XsDQQ
(The user sadsack did it)
www.deviationtx.com/forum/3-feedback-que...vo7e-replacement-lcd
I found a screen that is compatible, but I have no idea how to connect it:
www.ebay.es/itm/Modulo-Lcd-Grafico-2-1-1...Tutoria/301052582832
I would appreciate any help because for me, what is really important is to learn.
Thank you very much again.
Last edit: 07 Feb 2017 22:54 by slim.
Time to create page: 0.286 seconds
