Devo 10 Flight switch warning
11 Feb 2017 03:07 #59049 by bigjohn8646
Devo 10 Flight switch warning was created by bigjohn8646
Hi There I have just got a secondhand Devo 10
when i switch it on I get Flight Switch on the display & a bleeping sound
Haw can I get rid of this and get back to normal operation
Regards John This email address is being protected from spambots. You need JavaScript enabled to view it.
11 Feb 2017 10:05 #59064 by FDR
Replied by FDR on topic Devo 10 Flight switch warning
...and what position the FMODE switch is in?
It should be in 0...
14 May 2017 02:52 #62292 by bigjohn8646
Replied by bigjohn8646 on topic Devo 10 Flight switch warning
hi there the flight switch is in the 0 and I still get the warning
Regards John
14 May 2017 07:48 - 14 May 2017 07:50 #62294 by vlad_vy
Replied by vlad_vy on topic Devo 10 Flight switch warning
It looks like you have at your model *.ini file line with FMODE=xxxx at [safety] section. You can delete it if you don't need it.
Last edit: 14 May 2017 07:50 by vlad_vy.
22 Jun 2017 02:25 #63083 by bigjohn8646
thank for all your help the problem is resolved that is working well
Time to create page: 0.090 seconds
